here's another consideration. how many thousands of volts do you have across your spark plug, which is grounded to the head,'
which has coolant inside it. I just got my zinc anode from Summit. I'll put it in the water pump housing, and check it in a year to see
if it is corroding. If so, that means aluminum and iron is not corroding, at least not as much.
