Author Topic: Door buzzer and dome light switch?  (Read 2076 times)
Offline EMCD
« on: November 03, 2013 - 06:14:11 PM »
My switch that's near the door hinge broke. Does anyone make a repop? It looks like a plunger type of a switch that make the dome light come on and the door buzzer come on? Thanks.
Re: Door buzzer and dome light switch?
« Reply #1 on: November 03, 2013 - 06:21:40 PM »
Offline anlauto
« Reply #2 on: November 03, 2013 - 06:26:50 PM »
If it's 2 prong than you're all set, replacement are readily available. Some E Bodies use a three prong on the drivers side. You could cut and splice the wires to get a two prong to replace the three if that's the case.
Offline EMCD
« Reply #3 on: November 03, 2013 - 06:29:05 PM »
It's a 72 Cuda. Can I pick up the part at napa or autozone?
Offline EMCD
« Reply #4 on: November 03, 2013 - 06:30:18 PM »
And it's the drivers side.
Offline anlauto
« Reply #5 on: November 03, 2013 - 06:31:59 PM »
Most likely, I know NAPA has the single prong ones, they should have two prong...
Offline anlauto
« Reply #6 on: November 03, 2013 - 06:33:40 PM »
Try Standard DS240T
Offline EMCD
« Reply #7 on: November 03, 2013 - 07:11:24 PM »
Thanks guys
Offline EMCD
« Reply #8 on: January 19, 2014 - 07:18:38 PM »
So, mine is a 3 pin. Any ideas where to get one?
Offline anlauto
« Reply #9 on: January 19, 2014 - 07:20:59 PM »
Have to look for a used one or NOS $$$$....They show up on EBay from time to time.
« Last Edit: January 19, 2014 - 08:20:23 PM by anlauto »
« Reply #10 on: January 19, 2014 - 07:30:48 PM »
That's a hard one to get.
NOS ones go for 50-100 bucks if you find one.
The drivers door was the only one to have it in 71'.
I sold one to member here a few months back.
Offline EMCD
« Reply #11 on: January 19, 2014 - 08:50:46 PM »
Weird. My Cuda was a 72, made in may of 1972. Can I convert it to two pole?
Offline anlauto
« Reply #12 on: January 19, 2014 - 08:54:50 PM »
I wonder if you could just convert it to two instead...good question  :dunno:
Offline v21jeff
« Reply #13 on: July 09, 2014 - 07:40:52 AM »
It is my understanding that each of those wires goes through switch to get ground. You don't want it back feeding through system by jumping wires together. I am going to try jumping two wires together with a diode.
Offline Katfish
  • 70 Challenger
« Reply #14 on: July 09, 2014 - 09:05:25 AM »
If they both touch ground, no reason for a diode.
