Author Topic: z-bar pics needed....installed  (Read 1483 times)
Offline challenger71
« on: November 05, 2013 - 07:37:27 AM »
Does anyone have a good pic of a z-bar installed in a big block car? I just purchased a brand new z-bar from Brewers performance and went to install it, and I cannot get everything to line up, especially the clutch adjustment rod. I originally had the wrong z-bar in the car, that is why I ordered a new one, but now I am running into this problem. It's almost like the pin for the adjustment rod is on the wrong side. Anyone have this problem?
10 years in the making......
Offline bigblue73
Re: z-bar pics needed....installed
« Reply #1 on: November 05, 2013 - 09:04:02 AM »
Try flipping it right to left so the other tab is towards the bellhousing.  See if that helps.
Offline anlauto
« Reply #2 on: November 05, 2013 - 10:20:04 AM »
If you're standing in front of the car looking down at the bar, this is how it should be installed.
First off, make sure you have it installed correctly.
Offline anlauto
« Reply #3 on: November 05, 2013 - 10:22:07 AM »
Now if your adjusting rod is on a radical angle, you should see if you have the correct length clutch fork, there are several diffenent ones.  http://www.brewersperformance.com/products.asp?cat=102  Yours could be too short or too long depending....
« Last Edit: November 05, 2013 - 10:24:24 AM by anlauto »
« Reply #4 on: November 05, 2013 - 02:13:18 PM »
 It is installed correctly. According to that brewers website all e-body small block and big block clutch forks are the same.
Offline anlauto
« Reply #5 on: November 05, 2013 - 03:25:11 PM »
Yes, all E Body clutch forks are the same. Do you know for sure you have the correct E Body clutch fork ? Take it out and measure it compared to the list on Brewers site.
« Reply #6 on: November 05, 2013 - 10:59:53 PM »
My car originally came with a 318 and a 4 speed and I used the same clutch fork.
« Reply #7 on: November 06, 2013 - 05:12:14 PM »
Looks like I have it figured out. I got the new z-bar installed and now the new problem is that the clutch fork is too long. It turns out that the moron that owned this car before me,put a matching z-bar and clutch fork and then bent the clutch adjustment rod to make it work. Aaaaaargh!!!! Does anyone have a used ebody clutch fork that they don't want an arm and leg for?
Offline anlauto
« Reply #8 on: November 06, 2013 - 05:45:08 PM »
Ah---hah ! :thumbsup:
