Author Topic: Reassembly of my 71 Cuda grille questions...Is it just THIS hard to do?  (Read 867 times)
Offline tuff340GranCoupe
I have a 71 Cuda grille that I just painted & its time to assemble this thing. Got the inner graters in place but what blowing my mind is how tough the inner C trims is to install! Really? When I disassembled it, I marked which one C goes where & when I try to fit in it, it hardly lines up at all! Also, which way to the clips for the C trim go, meaning which way do the small 'teeth' go? After even forcing the trim into place its does not line up! WTF! I only got one C into place & its not 100% back into place & its looks like crap!
So, what's the trick? Am I doing something wrong or are these just that tough to assemble? This is my first 71 grille & by the looks of this, its going to be my last! I have restored about 12 1970 Cuda grille & a handfull of 72-74 units. Can anyone give advise before I really either bust something on assembly or really F something up??
email: cudamaster7074@gmail.com
« Last Edit: November 09, 2013 - 10:49:48 AM by tuff340GranCoupe »
Offline anlauto
Re: Reassembly of my 71 Cuda grille questions...Is it just THIS hard to do?
« Reply #1 on: November 09, 2013 - 11:13:22 AM »
I've done about a half dozen or so, just takes time and patience not to scratch the fresh paint. :2cents: You're lucky you marked the "C" trim because all six are different and only fit in one way. Teeth to the inside if I remember correctly. :clueless:
Offline LEMOOREACE
  • I was a llama, but I have since evolved.
« Reply #2 on: November 15, 2013 - 06:51:19 PM »
I marked mine but had no issues..  a little bit of trickery but overall they all went in as expected..
