Author Topic: Sure Grip definition  (Read 5869 times)
Offline polarbear123
Re: Sure Grip definition
« Reply #15 on: November 15, 2013 - 10:31:03 AM »
if you had a spool you would know , the sure grip should stay locked until there is enough different speeds at the wheel to cause the friction of the sure grip to be overcome . if you had a spool the inner tire would sqeal at almost any speed in a corner
