Author Topic: Green Axle Bearings  (Read 5290 times)
Offline Travis72
Re: Green Axle Bearings
« Reply #15 on: November 16, 2013 - 12:41:43 AM »
Dan who drives and maintains the E-max Hotchkis Challenger told me that E-max has green bearings and that they replace them after every race weekend.  They just treat them as a maintenance wear item.  Of course E-max is driven REALLY hard and on sticky tires so your experience may vary.
Travis
72 Cuda
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #16 on: November 16, 2013 - 07:56:05 PM »
And for the guys that might think the factory tapered bearings are better than the greens. Some great info here http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=4740404&page=0&fpart=1&vc=1
Offline 72cudamaan
« Reply #17 on: November 16, 2013 - 08:27:06 PM »
Looked like about a 50/50 mix of opinions. Never ran green bearings, so I couldn't say either way other
than what I've read and/or heard.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline 73EStroker
« Reply #18 on: December 09, 2013 - 02:14:51 PM »
Ford Falcon GTs and GTHOs in Australia ran ball bearings in the diff. Believe older Mustangs did here as well. Only ever saw one wheel c/w axle attached come out in a track car. No issues with mine but I bought the snap ring type. I just check them each car season.
Barry (Salmon Arm)
Offline GreenFish
« Reply #19 on: January 05, 2014 - 05:41:32 PM »
If Dr. Diff says run Green bearings thats pretty much all I need to hear.  I doubt there are too many people who know more than he does on the subject.
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #20 on: January 10, 2014 - 06:19:40 PM »
 After reading the Dr diff article it sounds like it is only the old style green bearings that are prone to premature wear and have gotten the bad rap but didn`t really see much of an argument to change from the factory tapered setup either.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
