Author Topic: rear end fluid change  (Read 614 times)
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« on: November 15, 2013 - 05:35:24 AM »
I changed my cuda's 3rd member unit in 1979 to a 3.91 sure grip.   I haven't done anything with the gear oil since then.  I am planning on changing the oil and making this a spring project in 2014.
-Do I drain the fluid from the fill plug by siphoning it with a hose?
-I need a recommendation on oil type, weight, brand....and any other additives that may be needed.
And yes, I kept the original stock 3.23 unit with 27,000 miles on it.
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Re: rear end fluid change
« Reply #1 on: November 15, 2013 - 07:16:25 AM »
you can buy a suction gun , looks like a grease gun to draw the fluid out .
 I would use 80-90w GL4 gear oil
