Author Topic: New K-Member  (Read 2160 times)
Offline cudabob496
New K-Member
« on: November 17, 2013 - 06:01:09 AM »
The new Popular Hot Rodding Mag has an article on a new bolt-in K member for B and E bodies, that cost
$650.  Made by QA1. Weighs about the same as stock, but opens up mega room under the engine.
2011 Kawasaki Z1000
Offline hemiken
Re: New K-Member
« Reply #1 on: November 17, 2013 - 06:09:39 AM »
Have you got pictures that you can post please :bigsmile: or maybe a link  :wave:
« Last Edit: November 17, 2013 - 06:20:30 AM by hemiken »
Offline cudabob496
Re: New K-Member
« Reply #2 on: November 17, 2013 - 06:17:04 AM »
2011 Kawasaki Z1000
Offline hemiken
Re: New K-Member
« Reply #3 on: November 17, 2013 - 06:22:22 AM »
Thank you for that :bigsmile: Looks like they are starting to get it and making them stronger, 2 bars are better than 1. Now if they put a tube cross brace between those two lower parralel bars and that would be a really strong front :wave: :clapping:
Offline inviolet
Re: New K-Member
« Reply #4 on: November 17, 2013 - 10:48:01 AM »
I know QA1 bought CAP Automotive, but Is this K frame any different form the one CAP Automotive Products use to make?
http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Board=Racer&Number=6860828&Searchpage=1&Main=6860828&Words=+JRod01&topic=&Search=true
Offline anlauto
Re: New K-Member
« Reply #5 on: November 17, 2013 - 11:03:26 AM »
Does it take stock LCA's ? I don't see where or how they mount.
Offline cudabob496
Re: New K-Member
« Reply #6 on: November 17, 2013 - 11:19:33 AM »
The mag article says it bolts in and can take all stock attachments.
But they do sell LCA's, etc, if you want them.
2011 Kawasaki Z1000
Offline cudabob496
Re: New K-Member
« Reply #7 on: November 17, 2013 - 12:01:15 PM »
mag article implies its all new
2011 Kawasaki Z1000
Offline 73EStroker
Re: New K-Member
« Reply #8 on: November 17, 2013 - 10:31:54 PM »
The thing that would interest me the most about this product would be a frame that takes all the stock components except we could install a rack and pinion steering arrangement. Not that POJ that is sold now with a host of u-joints to curve around to the steering box.most likely barking up a tree here tho!
Barry (Salmon Arm)
Offline cudabob496
Re: New K-Member
« Reply #9 on: November 18, 2013 - 05:27:43 AM »
Be nice if they made a lightweight one, with chrom-moly medals, or something.
but how can you complain for $650!  Last new set up I saw was $3000.
Heck, make one out of aluminum!!!
2011 Kawasaki Z1000
Re: New K-Member
« Reply #10 on: November 18, 2013 - 08:50:09 AM »
I have yet to find a good rack system or the benefits , if the rack is in the rear you can use factory spindles but you still have oil pan clearance issues & header fitment is no easier , if you move the rack to the front you now need a different splindle / lower ball joint to get the right ackerman angles which I have yet to locate + most racks increase turning radius by not turning the hweels as much . I still think a stage 3 box or the faster ratio Borgeson is a better way to go .
Offline cudabob496
Re: New K-Member
« Reply #11 on: November 19, 2013 - 06:28:43 AM »
Seems like it would be easy to modify, and weld in some bars where you want them.
2011 Kawasaki Z1000
