Author Topic: 440 Flywheel Mounting Bolts  (Read 775 times)
Offline 7Dcuda
« on: November 18, 2013 - 10:04:20 AM »
Are the flywheel mounting bolts just grade 8 bolts or are they a special one time use type bolt?  I guess my real question is can I re-use the ones I currently have?
« Last Edit: November 18, 2013 - 10:12:54 AM by 7Dcuda »
Offline 72cudamaan
Re: 440 Flywheel Mounting Bolts
« Reply #1 on: November 18, 2013 - 12:55:50 PM »
Should be able to reuse the old ones unless there is an indication that they were loose at some point. If
they were loose you may see the sides of the bolts shiny or flattened threads. Of course you could probably get
a set of ARP's for fairly cheap if you wanted peace of mind.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #2 on: November 18, 2013 - 12:57:32 PM »
thread locker is a must, even if you use the old ones
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline 7Dcuda
« Reply #3 on: November 18, 2013 - 01:11:15 PM »
Cool, thanks for the replies fellas.  Yeah, I'll be using blue lok-tite for sure.
