Author Topic: Manual brakes vs. Power brakes? Aghhh....  (Read 8947 times)
Offline AU6pack
« on: November 21, 2013 - 12:09:36 AM »
Hi again,
I am wondering what the practical difference is between power boosted brakes and non boosted brakes are? I am running the bendix booster in my 70 Challenger and am having a hell of a time finding a place for the fluid reservoir for the hydrolic clutch.
The booster is out and only place it will fit fouls on the hood bracket   :stomp: Mounting it anywhere else will wither be impractical to fill or stand out too much.
While its out I'm thinking maybe ditch the power one and go for a manual unit where space wont be an issue.
Any plus or minus with each and any recommendations of what will work best with minimum mods? I would like a bolt in replacement if possible.
I'm doing plenty of upgrades and do want stopping power.
Thanks.
Craig
Melbourne, Australia
1970 Challenger 416 6 pak
Resto thread - http://www.cuda-challenger.com/cc/index.php?topic=114787.0
Offline 72bluNblu
Re: Manual brakes vs. Power brakes? Aghhh....
« Reply #1 on: November 21, 2013 - 01:10:15 AM »
Power brakes don't improve your stopping power, they just make it easier on your foot. Pedal effort is the only thing that is different, the actual brakes are the same, so is the stopping distance. Honestly, I prefer manual brakes. My challenger has power brakes, but my duster has manual brakes and the manual brakes have a much better pedal feel. Both cars have 11.75" disks. The duster had to stay manual because of the cam in its 340, but I'm glad I kept them. Heck I may even convert my challenger.
Offline ChallengerHK
« Reply #2 on: November 21, 2013 - 01:12:05 AM »
My car came with manual and I've never looked back. My father drove a 72 Newport with power, and the brakes were very over-boosted, very touchy.
- Han Solo, Star Wars
Offline AU6pack
« Reply #3 on: November 21, 2013 - 02:34:17 AM »
Thanks guys. I think that's the way I'll go - manual.
Any tips on brands? Vendors?
Craig
« Reply #4 on: November 21, 2013 - 07:02:21 AM »
Add me to the count , both my Charger & Chall have non power disc brakes , the other option is using hydro boost which is much smaller & uses pressure from the power steering to boost which is far better as many performance engine do not make enough vacuum to run the brakes effectively .
Offline CUDA JAS
  • vroooooom!
« Reply #5 on: November 21, 2013 - 09:31:13 AM »
I think doctor diff sells a nice kit using a newer MC.
I also have non-power brakes on my cuda.
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline ToxicWolf
« Reply #6 on: November 21, 2013 - 10:36:54 AM »
I like the hydro boost idea and may give a try one of these days.
« Reply #7 on: November 21, 2013 - 12:42:49 PM »
I've been contemplating that too. I've driven a hydroboost vehicle and it had a nice feel.
Offline AU6pack
« Reply #8 on: November 21, 2013 - 11:55:51 PM »
With a $1100.00 price tag and pretty ugly looks, i think i will just do the standard manual wilwood unit for now. The published weight is 30 lbs compared to 6 lbs for the plain jane Wilwood unit.
Thanks for the responses guys.
Craig
Offline ToxicWolf
« Reply #9 on: November 22, 2013 - 07:22:41 AM »
 :roflsmiley: It is kind of ugly.
« Reply #10 on: November 22, 2013 - 07:26:09 AM »
$1100 ? :faint:  I've got $50 bucks into mine so far, and just need to finish the mounting plate and buy/make the lines to connect it all up?
Offline cordodge
« Reply #11 on: November 22, 2013 - 07:42:16 AM »
hey brad, i am assuming you got one from an astro van do you know what year vans to get them from?  thx bruce
1970 challenger 95% done
1969 roadrunner in progress
1969 D-100 13,000 mile truck
1969 L-700 tilt cab in progress
2007  Dodge Ram 4x4
2017 hyundia Santa fe ultimate
1977 VERY UNDERSTANDING WIFE !! 😇
« Reply #12 on: November 22, 2013 - 07:44:52 AM »
Yes it's from an Astro van, not sure what year though? In the 90's somewhere? Pretty common.
Here is the required line info courtesy of Barry
« Last Edit: November 22, 2013 - 07:50:17 AM by brads70 »
« Reply #13 on: November 22, 2013 - 08:02:10 AM »
If it helps...Here is some info for dimensions for making the mounting plate I found on the net. Others have said it's better to use the bell crank( under the dash) from the power booster set up other wise they are too sensitive? A member here (John) set me up with one. Also it's suggested to use a 1 1/8" master cylinder. (GM uses a
1 1/4" )I just haven't got off my butt to finish this up yet. That and I'm getting used to manual brakes.  :lol:
This mounting is not the best, makes the brakes too sensitive I'm told?
« Last Edit: November 22, 2013 - 08:04:00 AM by brads70 »
« Reply #14 on: November 22, 2013 - 03:51:09 PM »
Don't know if I could bring myself to put parts off a CHEVY ASTRO VAN  :eek4:  on my Challenger. Just sayin'
