Author Topic: Looking for brake photos  (Read 2449 times)
Offline mrbill426
    • All Around Mopars
« on: November 23, 2013 - 08:10:21 PM »
Does anyone have good clear photos of installed rear (shoe) brake systems?  I'm looking for shots that show all the springs, shoes, and cables correctly mounted; if it matters they are 10" brakes.  Axle shafts pulled out would be a bonus  :thumbsup:
Thanks in advance!
 :working:
MOPAR or NO car!
'72 'Cuda 340, white on white
'72 Sebring; bracket project
'66 Imperial Crown; parts car
Re: Looking for brake photos
« Reply #1 on: November 24, 2013 - 08:26:59 AM »
I assume you do not have the factory service manual ?
Offline Jesus H Chrysler
« Reply #2 on: November 24, 2013 - 10:07:55 AM »
Ask and ye shall receive.  This is the drivers side.  That's important for spring and cable placement.  Use the mirror image for the passenger side.
BTW the "small shoe" always goes in front.  :2thumbs:
Yes I own a 1972 Dodge Challenger Convertible T/A S/E with a 440 Six Pak. Can it get any more wrong?
{OO /===\ OO}
(OO==> <==OO)
Greg, in the middle of MA has:
1970 Dodge Coronet 440 "Zom Bee"
1972 Dodge Challenger convertible 440 5 speed.
1973 Dodge Challenger 318 "Brown Bomber"
2012 Dodge Challenger R/T Classic Blackberry Pearl.
2001 Jeep Wrangler locked, lifted and lighted.  "Jeep is a registered trademark of Chrysler Corporation"
Offline mrbill426
    • All Around Mopars
« Reply #3 on: November 24, 2013 - 10:48:18 AM »
Thanks Jesus, that's what I need  :thumbsup:  I'll have to look but I am not sure my brake bars have that 90 degree bend on the one (front) end, and yes I knew about the primary/secondary shoe arrangement.
No, Chryco I don't have an FSM, only Chiltons and Haynes and the pictures are lousy.
As for the gaskets, am I right that the metal ones go behind the backing plates and the foam ones go behind the axle bearing retainers???
 :working:
MOPAR or NO car!
« Reply #4 on: November 24, 2013 - 12:55:38 PM »
I believe this pic is of an A-Body, but E-Bodies are the same.  I think mine has a 45 degree bend where this one has a 90, but you want it to the front anyway.  The back engages the e-brake arm.
{OO /===\ OO}
(OO==> <==OO)
Offline mrbill426
    • All Around Mopars
« Reply #5 on: November 24, 2013 - 01:13:27 PM »
Okay thanks!  My brake bars do have a shorter 45 degree bend, and also my upper return springs are one short and one long (maybe wrong ones installed before??); the adjuster cables and levers look the same though.  Is the adjuster cable "washer" end supposed to be sandwiched between the (upper) return spring hooks, or lay flat against shoe retainer?
 :working:
MOPAR or NO car!
« Reply #6 on: November 26, 2013 - 09:57:15 PM »
11" are different , the cable should be behind both springs
Offline mrbill426
    • All Around Mopars
« Reply #7 on: November 26, 2013 - 10:44:13 PM »
Does this look right?
MOPAR or NO car!
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #8 on: November 27, 2013 - 05:39:47 AM »
 :working:
when i put my 3.91 unit in i had to pull the axles out if remember correctly.  replaced the foam gaskets then.  you can see it in this picture.
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
« Reply #9 on: November 27, 2013 - 07:32:24 AM »
looks right to me
Offline Katfish
  • 70 Challenger
« Reply #10 on: November 27, 2013 - 08:24:16 AM »
Offline mrbill426
    • All Around Mopars
« Reply #11 on: December 25, 2013 - 11:46:09 PM »
Thanks for the help guys!  :bigsmile:
MOPAR or NO car!
