Author Topic: Backup light not working  (Read 942 times)
Offline Giveitawack
    • ebay
« on: November 24, 2013 - 01:45:26 AM »
It worked the first years after the restoration. But then it stopped working. I have replaced the switch two or three times. No result.
I assume that something that pushes the switch isn't pushing enough.
Can something inside be adjusted?
« Last Edit: December 04, 2013 - 11:14:27 PM by Giveitawack »
Re: Backup light not working
« Reply #1 on: November 24, 2013 - 02:03:01 AM »
4 spd or auto ?
How far can you trace power to , it should go to the reverse switch & back out to the firewall / bulkhead plug & continue into the rear harness connected behiond the kick panel & to the rear of the car
Offline Giveitawack
    • ebay
« Reply #2 on: November 24, 2013 - 03:50:20 AM »
727
Have not traced.
Got all new M&H harnesses
« Reply #3 on: November 24, 2013 - 07:53:23 AM »
check the ground at the socket. a little sandpaper on the aluminum housing did the trick for me?
Offline Giveitawack
    • ebay
« Reply #4 on: November 24, 2013 - 08:32:31 AM »
Good idea.
Thanks
Offline rattlesnake
  • Rattlesnake
« Reply #5 on: November 24, 2013 - 11:17:31 AM »
Just went through this on my 70 Cuda. First of all the switch actually works opposite what your thinking. When your tranny is in reverse the switch is released from being pushed in which complets the circuit, when the car is in any other gear the button on the switch is pushed in which in turn interrupts the circuit. I beat my head against the wall on this and I ended up having the wrong switch, one was shorter that the other. If you have changed the switch make sure the new one is the same as the one that worked. The difference is in the length and they have to be lying next to each other to even see it. If it is the same start at a location where you know you have power and track it to the back until you lose power on your tester. Common problems are grounds at the receptacle, contact points inside the socket and supposed new bulbs that are junk.
keep honking I'm reloading
Offline Giveitawack
    • ebay
« Reply #6 on: November 24, 2013 - 12:37:15 PM »
Come to think of it
The starter function works. Always in neutral and almost always in park.
The switch has two stages?
