Author Topic: Do we need a PCV System?  (Read 7044 times)
Offline cudabob496
« on: November 25, 2013 - 10:02:21 AM »
Do we have to have a PCV system, if we change our oil regularly?
Isn't venting the crank case through the valve cover breathers good enough?
2011 Kawasaki Z1000
Re: Do we need a PCV System?
« Reply #1 on: November 25, 2013 - 10:06:04 AM »
Benefit of PCV is to create negative pressure in crankcase, pressure causes oil leaks & blow by, so unless you like oil leaks install one.
Offline cudabob496
« Reply #2 on: November 25, 2013 - 10:07:32 AM »
But I have valve cover vents on both valve covers.
2011 Kawasaki Z1000
« Reply #3 on: November 25, 2013 - 10:08:27 AM »
  You need negative pressure, see my edit
Offline cudabob496
« Reply #4 on: November 25, 2013 - 10:18:50 AM »
OK, but I'm trying to figure how to get negative pressure in the crankcase, with breather vents on both
valve covers.  Seems the vents will pass a lot more air than the little vacuum port on the side of my carb.
I'm tired of the PCV system sucking oil into my intake. Am building a PCV oil separator, but now thinking
of disconnecting the PCV line instead.
Maybe the "tree huggers" demand it.  We are putting junk into our intake, which certainly ain't
making more power.
« Last Edit: November 25, 2013 - 10:21:28 AM by cudabob496 »
2011 Kawasaki Z1000
« Reply #5 on: November 25, 2013 - 10:20:36 AM »
I guess that's why the factory puts a breather on one side & the PCV on the other. Could you not do the same?
Offline cudabob496
« Reply #6 on: November 25, 2013 - 10:22:33 AM »
Have PCV line on P/S valve cover, and vents on both valve covers.
2011 Kawasaki Z1000
« Reply #7 on: November 25, 2013 - 10:38:58 AM »
I can see where having a vent/breather on the same side allows a easy path for air to be sucked at probably higher velocity than intended, you also would not get the benefit of negative pressure in the block...try taking the breather off & plugging the hole on the side with PCV.. just might solve the issue.
Offline cudabob496
« Reply #8 on: November 25, 2013 - 10:56:40 AM »
The main issue I'm having now is oil getting into the PCV line, causing the engine to use more oil than it should.
Think I'm gonna remove the PCV line from the valve cover, block it off to the carb, and install another breather where
the PCV line hole is now. That way I'll have 3 vents to keep crank case pressure from getting too high, and maybe solve
my oil consumption issue.
2011 Kawasaki Z1000
Offline HP_Cuda
  • Mopar or No Car!
« Reply #9 on: November 25, 2013 - 11:34:09 AM »
The one question you have to ask yourself is do you want pressure buildup inside your motor?
Otherwise that pressure will come out via blow-by and a ton of white smoke.
« Reply #10 on: November 25, 2013 - 11:37:32 AM »
Run a hose off of each valve cover and plumb them into the header collectors...or exhaust pipes.  The flow of exhaust will create a vacuum and pull vapors out of the crankcase.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #11 on: November 25, 2013 - 11:44:31 AM »
The only problem with using exhaust to ventilate is that you need to have straight through mufflers otherwise you buildup a nice pool of oil and can cause a muffler fire over time.
« Reply #12 on: November 25, 2013 - 11:49:37 AM »
I've never heard of that before. Even a straight through muffler has perforations in the pipe that would let oil collect in the bottom of the case. I would think the exhaust temp when fully warmed up would burn off the oil before it had a chance to collect.  If you had that much oil pooling in a muffler, I think you'd have major engine issues.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #13 on: November 25, 2013 - 11:52:23 AM »
You'll see when you go to buy those exhaust evac systems they warn you to only use on a straight through muffler.
But hey anyone can do whatever they want. I was actually thinking of using one but after buying some expensive flowmasters I decided to go the separator route and it's worked great.
Offline cudabob496
« Reply #14 on: November 25, 2013 - 12:22:10 PM »
How can pressure build up if I have 3 breathers total on the valve covers?
2011 Kawasaki Z1000
