Author Topic: Removing side glass - how to  (Read 3767 times)
Offline AU6pack
« on: November 27, 2013 - 02:26:06 AM »
Hi guys,
Any posts on how to easily remove the side glass (driver & rear quarter) or tips? Cant seem to find anything....
Thanks.
« Last Edit: November 27, 2013 - 03:28:27 AM by AU6pack »
Craig
Melbourne, Australia
1970 Challenger 416 6 pak
Resto thread - http://www.cuda-challenger.com/cc/index.php?topic=114787.0
Offline Fern
« Last Edit: November 27, 2013 - 06:49:56 AM by fern »
Offline Travis72
Re: Removing side glass - how to
« Reply #2 on: November 29, 2013 - 04:53:39 PM »
I took a bunch of pics and posted in this thread:
http://www.cuda-challenger.com/cc/index.php?topic=84250.msg889426#msg889426
Travis
72 Cuda
Offline AU6pack
« Reply #3 on: December 06, 2013 - 07:24:22 PM »
Thanks guys - very useful threads  :2thumbs:
Craig
Offline AU6pack
« Reply #4 on: December 07, 2013 - 08:28:43 PM »
Sorry guys.... more (dumb) questions:
Front weather seals:
1 - How do you remove the front door weather seals from the doors to help window removal?
2 - What are these called (whiskers?) and who is a good vendor for replacement strips if they need to be replaced?
Rear quarter windows:
I want to remove and replace the rubber seal on the rear quarters.
1 - How do you remove the chrome trim from the glass
2 - Who is a good vendor for the replacement weather strip?
Its a 70 Challenger...
Thanks
Craig
Offline 72cudamaan
« Reply #5 on: December 07, 2013 - 08:56:47 PM »
Thanks
Roseville has the rubber strips. You don't have to remove the stainless strip on the quarter window to replace
the rubber. It kind of rolls out. Reinstall with black weatherstrip adhesive. Door whiskers available from Roseville
also. Wherever you buy from, just make sure you use Topcat brand.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline AU6pack
« Reply #6 on: December 07, 2013 - 09:26:19 PM »
Thanks Cudamaan.
 How do i get the whiskers off the doors?
Craig
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
« Reply #7 on: December 08, 2013 - 04:24:13 PM »
Thanks Cudamaan.
I recently did mine.  To remove the cat whiskers from the doors, just pull mostly up and slightly in towards the car; starting at either the front or rear of the door.  You may need the help of pliers or vise grips to get a good hold on them.  They are held on with clips that are attached to the whiskers.  It takes a bit of yanking and pulling, but they will come off.  Mine were unusable afterwards, as they got all bent and distorted in the removal process, but I didn't care because I had brand new replacement TopCat whiskers.  I've heard they are the best.  The 1/4 rear glass weatherstrip can either be slid into the stainless channel, or set in place and tucked under the lip of the strip.  Just be sure to align the the small protruding tabs (on the inside of the stainless strip) with the indents in the weather strip, and use the black weatherstrip adhesive.  Not too much though as you'll have to do cleanup of the excess that will ooze out.
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
Offline 72challcan
« Reply #8 on: December 08, 2013 - 08:47:46 PM »
This is excellent info.  Replacing door glass in 70 convert and think this will really help. Thanks for the detailed info Frank
Offline AU6pack
« Reply #9 on: December 09, 2013 - 04:51:42 AM »
Great info - thanks.
Craig
Offline 484HemiCuda
« Reply #10 on: August 08, 2019 - 04:51:54 PM »
I need help getting the quarter glass out from my '70 Barracuda.  I have the two bolts out that hold the gladd and the wiskers removed.  Is there any trick to getting the glass out?
Offline 4Cruizn
  • HEMI FISH
« Reply #11 on: August 09, 2019 - 10:37:22 AM »
Here is a thread I started on the other site that has a ton of great info on glass replacement!  I was working on a 70 convertible!
https://forum.e-bodies.org/body-shop/5/cuda-door-and-side-window-replacement/371/
