Author Topic: Radio Opening  (Read 710 times)
Offline dave73chally
Radio Opening
« on: November 27, 2013 - 01:09:55 PM »
Previous owner installed a headunit that is now trash. When I pulled the headunit, the opening looks has a slot for the single DIN then a smaller slot below, I'm assuming this was originally an 8 track? The previous headunit was just sitting there, not fully supported. Is there a different plastic panel that will insert behind the radio bezel trim to fit a single DIN radio? If so can someone please point me in the direction of a supplier.
73 Challenger
Offline 4Cruizn
  • HEMI FISH
Re: Radio Opening
« Reply #1 on: November 27, 2013 - 01:20:59 PM »
Might need a picture to see what you have going on . . . .   :clueless:  Do you have something like this?
« Last Edit: November 27, 2013 - 01:23:15 PM by 4Cruizn »
Re: Radio Opening
« Reply #2 on: November 27, 2013 - 01:40:40 PM »
^ Yea that's exactly what I have
73 Challenger
Re: Radio Opening
« Reply #3 on: November 28, 2013 - 12:42:22 AM »
Nothing fits well , the opening is similar to a single din but the trim panel curves over the end  of it you can carve out the din opening & move it away from the trim slightly or notch the trim to clear , E bodys had a unique radio that fits nothing else , the 71 Charger Roadrunner had a unique radio also .
Offline hemiken
Re: Radio Opening
« Reply #4 on: November 28, 2013 - 06:10:52 AM »
This radio panel that 4C posted up is the generic part used on all radio fitments from factory, they did it this way to allow a standard radio to fit and when you have an 8 track the bezel is recessed to allow viewing and access to the lower 8 track section. The only radio panel that was different from what 4C posted is the 1970-71 Challenger panel that is the same with ribs and then ther was a radio delete panel that had no access hole at all for a radio fitment. :2thumbs:
Offline 4Cruizn
  • HEMI FISH
Re: Radio Opening
« Reply #5 on: November 28, 2013 - 10:37:10 AM »
I also have this piece but not sure of its application??
