Options for 4 brl oval air cleaner
Author Topic: Options for 4 brl oval air cleaner  (Read 2315 times)
Offline 360FISH
  • BS23H3B567746
« on: November 28, 2013 - 04:43:19 PM »
Hey guys,
I’m restoring an AAR hood and eventually want to get an oval air cleaner that fits a 4 barrel (sits on top of a FAST ezEFI system)…  a normal round air cleaner fits so I’d hope an oval base would work.
I plan to contact Hybrid Fiberglass Solutions…  they make a custom base that should work, but I’m curious what other options might be out there that you guys have heard of.
Thanks,
Alan
1973 ‘Cuda   Semi-Pro Touring
360 SB - 518/OD auto tranny - FAST EZ EFI - Edelbrock Fuel sump - HHR fan
Hella H4 headlights on relays - 97 Dodge Avenger seats - Chin spoiler - Bumpers pulled in to ’72 offset
Build: http://www.cuda-challenger.com/cc/index.php?topic=74674.0
Re: Options for 4 brl oval air cleaner
« Reply #1 on: November 28, 2013 - 06:39:45 PM »
I HAVE A 383 rOAD rUNNER a/c available
« Reply #2 on: November 28, 2013 - 09:29:23 PM »
The 440 base will give you the most hood clearance . I'm using the Hybrid fiberglass base.
There is this... but it won't seal to the hood like the AAR-T/A base
http://www.pgclassic.com/product_info.php?products_id=474&osCsid=d478102f87a518420e6982d0523ace1c
Offline 360FISH
  • BS23H3B567746
« Reply #3 on: November 29, 2013 - 12:59:20 PM »
So that's the rub with the air grabber...  it won't seal to the AAR hood?
One of my goals is to take the car on a Power Tour and it looks like it rains at least once during the week long run.  I recently had the fish out in the rain here in Cali (with the raley hood).   I would think the seal is important.   Have you guys seen anyone try to seal it or come up with options?   Maybe I could close the scoop with something on rainy days.
Also, isn't one of the ideas behind the seal to keep warm engine air out of the carb?
Chryco, the air grabber sounds like a cool option (they look good).  I want to keep researching this to make sure I understand the pros and cons.  Thank you  :)
« Reply #4 on: November 29, 2013 - 01:20:34 PM »
The idea of the seal is to provide a "ram air" effect. If your planning on being able to block the hood when it rains then the one I posted the link to would work best for you IMO
Offline 360FISH
  • BS23H3B567746
« Reply #5 on: November 29, 2013 - 08:17:49 PM »
I guess I'm looking to do both.  I thnk I saw someone build a "seal/enclosure" to the bottom of their hood that sat around the air cleaner...  seems like a kludge...
I don't know the measurements of the air-grabber to know if it even makes sense to try.
I assume you like the Hybrid piece?
« Reply #6 on: November 29, 2013 - 09:16:37 PM »
It works for me ok.
Here is a link for researching air cleaners.
http://www.nicksgarage.com/aircleaner.htm
Offline HP_Cuda
  • Mopar or No Car!
« Reply #7 on: November 30, 2013 - 12:29:21 PM »
Wow Brad great resource for great air cleaner info!!!
Offline Jesus H Chrysler
« Reply #8 on: November 30, 2013 - 12:55:23 PM »
Looks like you're trying to get the best of both worlds.  I don't blame you, but it's not going to be easy.  I also have a T/A hood, and originally wanted the air cleaner to seal up properly against the hood just like factory.  I was going to use the factory 340 piece.  After a lot of searching I couldn't find an affordable T/A base, and settled on the standard 440 Six Pack setup.  Here were my considerations doing this:
1. Mine isn't a factory correct car, so no need to worry about factory correct parts.
2. The ram effect of the T/A (and I suspect AAR) hoods doesn't come into play until you're right around the speed limit anyway, and the seal would have to be perfect.
3. My car isn't a race car.
4. My car is far more likely to be caught in the rain than have a use for the ram effect, so keeping the air cleaner base unsealed keeps the rain water from flooding the element.
In your situation, your options are more limited.  Since the AAR hood was designed specifically for the 340 Six Barrel, there was no 4 barrel option for the sealed base.  You could use the single four oval air cleaner option which would give you the same benefits I have, but you wouldn't have the factory look or ram effect if that's what you're looking for.  In order to have a sealed base 4 bbl you would either have to cut up and modify a steel 6 bbl base, or see if someone makes that particular combination in fiberglass, like Hybrid.
Here's a handy blurb from Mopar Muscle:
http://www.moparmusclemagazine.com/techarticles/engine/mopp_0212_air_cleaner_spotters_guide/photo_17.html
And a few detailed pics from someone selling one:
http://www.2040parts.com/1970-aar-cuda-340-6-pack-factory-air-cleaner-assembly-six-pack-oem-i51101/
Yes I own a 1972 Dodge Challenger Convertible T/A S/E with a 440 Six Pak. Can it get any more wrong?
{OO /===\ OO}
(OO==> <==OO)
Greg, in the middle of MA has:
1970 Dodge Coronet 440 "Zom Bee"
1972 Dodge Challenger convertible 440 5 speed.
1973 Dodge Challenger 318 "Brown Bomber"
2012 Dodge Challenger R/T Classic Blackberry Pearl.
2001 Jeep Wrangler locked, lifted and lighted.  "Jeep is a registered trademark of Chrysler Corporation"
