Author Topic: Heater Box TRASH to TREASURE  (Read 5554 times)
Offline shoooter
Re: Heater Box TRASH to TREASURE
« Reply #15 on: February 04, 2014 - 11:32:21 PM »
what colour should the metal brackets be painted on a 71 cuda with AC? there is a outside black bracket and the other metal colour ones.
Offline elmoska
« Reply #16 on: March 10, 2014 - 09:28:38 PM »
on the bottom right of the first picture, how do you remove this door
1974 challenger on its way..
Offline elmoska
« Reply #17 on: March 14, 2014 - 07:25:49 AM »
 :thinkerg:
Offline shawge
  • Zoiks!!
« Reply #18 on: March 14, 2014 - 03:24:16 PM »
Did you figure it out?  You have to snake it out but it should come out.  May be a bit hard to do if there's rust in that area.
- Jerry
Offline elmoska
« Reply #19 on: March 15, 2014 - 11:21:58 AM »
do i have to remove the metal bracket with the 2 rivets ? or do i have to twist the door or something because of the s shaped rod
Offline anlauto
« Reply #20 on: March 16, 2014 - 09:00:55 PM »
Yes
Offline elmoska
« Reply #21 on: March 30, 2014 - 02:23:27 PM »
restoration is almost done.
on this door is there a metal washer on both side or just on one side ?
Offline elmoska
« Reply #22 on: May 23, 2014 - 08:07:58 PM »
i'm looking for the  off/heat/def  cable, it has been cut by the previous owner.
i heard people here talking about 2 hook for the heater box .. should i have those hook on my 74 challenger non a/c box. and were should it goes.
Offline crash340
« Reply #23 on: May 23, 2014 - 09:36:56 PM »
Alan,
when you restored that heater box, what did you coat it with please, a clear sealer, paint color ???
Greg
Greg
73 Cuda
Brisbane, Australia
Offline anlauto
« Reply #24 on: May 24, 2014 - 05:33:34 AM »
I wet sand the box with 600 then clear coat with Satin Clear. This box had a couple of fiberglass repairs as well which I paint with a mixture of greys and blacks before the clear coat
Offline mrbill426
    • All Around Mopars
« Reply #25 on: May 25, 2014 - 12:09:23 PM »
Looks terrific!  :thumbsup:
MOPAR or NO car!
'72 'Cuda 340, white on white
'72 Sebring; bracket project
'66 Imperial Crown; parts car
