Author Topic: Heater Box TRASH to TREASURE  (Read 5557 times)
Offline anlauto
« on: November 29, 2013 - 06:29:29 PM »
Ok....I've worked with some bad parts before but this Heater Box has to be the worse sample I've ever had to restore....
The guy who supplied me with this junk is a member here so I won't bash him too much....He no longer owns the car, so I'm guessing he don't really care... :roflsmiley:
Here's what greeted me first thing this morning...
Offline anlauto
Re: Heater Box TRASH to TREASURE
« Reply #1 on: November 29, 2013 - 06:33:09 PM »
Six hours later, with the help of a "deluxe" gasket kit from DMT  and a new heater core.....
There are still some areas actually missing, but I just fixed the cracks and trimed the broken edges to clean it up some...
This isn't going in an OE Gold car by any means, but once mounted in place it will "do the job"  :2thumbs:
« Last Edit: November 29, 2013 - 06:34:51 PM by anlauto »
Offline anlauto
« Reply #2 on: November 29, 2013 - 06:35:55 PM »
Oops...Just realized I didn't restore the "hook" :banghead:
« Reply #3 on: November 29, 2013 - 06:48:23 PM »
I just threw up in my mouth a little. I can't believe you forgot that! :o
 :roflsmiley:  Just kidding! :misbehaving:  Looks terrific! Good job! :2thumbs:
Offline filmsurgeon
« Reply #4 on: November 29, 2013 - 09:51:05 PM »
Very nice work!  I am doing my non-A/C heater box for my '70 Challenger myself.  Bought the DMT kit as well.  I did the disassembly a while back and some painting of the metal parts, so I'm at the point now where I just need to apply the gaskets and reassemble.  If you don't mind me asking, what did you do to get the housing (plastic/fiberglass) to look new, and how did you get the yellow part number stamp to look new?  Thanks.
Offline anlauto
« Reply #5 on: November 29, 2013 - 10:49:15 PM »
I wet sand the box with 600 then clear coat with Satin Clear. This box had a couple of fiberglass repairs as well which I paint with a mixture of greys and blacks before the clear coat.
I had the stamps remade at my local Staples Store, but I'm pretty sure Sylvain sells them http://www.71sg.com/stamps.html
« Reply #6 on: November 29, 2013 - 10:53:01 PM »
Seems every one I've seen used has a broken edges at the lower foot area.
was yours?
Offline Cuda Cody
  • Vancouver, WA
« Reply #7 on: November 30, 2013 - 12:53:38 AM »
Nicely done my friend!   :clapping:
Offline ChallengerHK
« Reply #8 on: November 30, 2013 - 01:31:58 AM »
Very impressive.
- Han Solo, Star Wars
Offline slsc98
« Reply #9 on: November 30, 2013 - 02:38:14 PM »
 :2thumbs:
Offline DAYLEY/CHALLENGER
« Reply #10 on: November 30, 2013 - 04:57:09 PM »
Yours was better that the one I pulled out of my car............you did a great job bythe way.   ..
http://www.papadaveonline.com/imagegalleries/19/index.html
http://www.papadaveonline.com/imagegalleries/24/index.html
I had the foam to make all the gaskets and such so with a little fiberglass work and the foam.......did mine and it turned out ok.  Yours looks factory.......
Dave or David
Offline anlauto
« Reply #11 on: November 30, 2013 - 05:58:16 PM »
Yep...Think you win on the amount of fiberglass repairs for sure ! Great job. :2thumbs:
Offline filmsurgeon
« Reply #12 on: December 14, 2013 - 05:37:54 PM »
Question - Should there be a gasket on the back-side of the bracket that is attached to the heater core's copper tubes? (see attached_annotated photo)  Thanks.
Offline anlauto
« Reply #13 on: December 14, 2013 - 11:50:55 PM »
Nope
Offline filmsurgeon
« Reply #14 on: December 14, 2013 - 11:56:28 PM »
