Author Topic: AAR HOOD pin disc what to use instead of riverts  (Read 473 times)
Offline AZDAN
« on: December 01, 2013 - 05:51:26 PM »
On the steel hoods the round disc is riveted to the hood. What is used on the fiberglass AAR hoods to attach the disc? Seems like the rivets would just destroy the fiberglass and unless some really odd long rivets were used I don't see how you could washer but maybe they did.
Offline anlauto
Re: AAR HOOD pin disc what to use instead of riverts
« Reply #1 on: December 01, 2013 - 06:24:25 PM »
You got that info backwards....
On Steel hoods the factory used self-tapping screws.
On fiberglass hoods the factory used pop-rivets.
Offline AZDAN
« Reply #2 on: December 01, 2013 - 11:32:46 PM »
do they use a washer to back up the rivet?  I would have thought the pop rivet would just pull through the fiberglass.
Offline 67vertman
  • Member since 9-23-2005
« Reply #3 on: December 02, 2013 - 09:28:38 PM »
You mighy try this site to see if you can find any referance pictures....
http://www.iccahome.org/
