vinyl top install question pillar line
Author Topic: vinyl top install question pillar line  (Read 1085 times)
Offline AZDAN
« on: December 01, 2013 - 06:00:22 PM »
Where should the seam be located on the front pillar on a 'Cuda? how far down the pillar shouls the sew seam be. Is at the very top? I thought it was down acouple of inches but he vinyl top has been removed before I bought the car. Thanks
Offline crash340
Re: vinyl top install question pillar line
« Reply #1 on: December 03, 2013 - 03:33:35 AM »
AZDAN, I have a 73 Cuda, I will have it at home tomorrow night, I'll get a couple of photo's and measurements for you.
Greg
Greg
73 Cuda
Brisbane, Australia
Offline Surfmichaels
« Reply #2 on: December 03, 2013 - 10:36:04 AM »
There is a trim piece that covers the end of the vinyl down on the pillar. If you have the trim piece it's clear where to cut....  EDIT: oops misread question
« Last Edit: December 03, 2013 - 11:47:17 PM by Surfmichaels »
« Reply #3 on: December 03, 2013 - 10:51:11 AM »
He's talking about the seam in the top...not where to cut the material at the bottom.  The seam is a couple inches down from where the A-pillar and roof join.
Offline anlauto
« Reply #4 on: December 03, 2013 - 12:49:28 PM »
If you buy a quality reproduction vinly top, this seam is already set. It falls where it falls.
« Reply #5 on: December 03, 2013 - 01:04:05 PM »
I've never installed one myself but I assume there is some front and back adjustment.  That would change the location of the seam a little wouldn't it?
Offline 72cudamaan
« Reply #6 on: December 03, 2013 - 01:31:04 PM »
That's what I figured. I just installed mine and the seam is somewhere near the top. I guess I should look.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline anlauto
« Reply #7 on: December 03, 2013 - 01:47:23 PM »
Well yes technically I guess it could/would vary....
I like your wheel/tire combo....reminds me of the Barrelcuda every time I see pictures...
Offline burnt orange
« Reply #8 on: December 03, 2013 - 06:45:02 PM »
Original vinyl 1970 Barracuda
16 inches from bottom of window trim.
« Last Edit: December 03, 2013 - 06:52:07 PM by burnt orange »
Offline AZDAN
« Reply #9 on: December 26, 2013 - 09:49:48 PM »
Thanks for the info. You guys always help out.
Offline DocMel
« Reply #10 on: December 27, 2013 - 09:29:45 AM »
I installed a new top last summer.  It went on easy, I had my wife help:  Key was was good prep, clean surface, patience and doing it a 1/4 at a time.  Low humidity is a plus
When I laid it on as a test fit, yes, moving it back and forth will alter that measurement.  So a historical OEM measurement will def help, but Ill bet measurements from the factory originals will vary.  Remember, allot of stuff was virtually slapped on as Q/A wasn't exactly rampant back in the day
