Author Topic: Mopar 72 340 block plymouth cuda dodge challenger  (Read 1473 times)
Offline Davesrrcuda
« on: December 01, 2013 - 11:24:41 PM »
Mopar 72 340 plymouth cuda dodge challenger block. 1600 or b/o
hot tanked bored plate honed line bored and deck squared. comes with forged crank thats been externally balanced and mag shot peened ground and polished.
All below parts are brand new:
ARP stud package fel pro gasket set brand new bearings plugs JE pistons and comes with ring set. 10.5 compression Eagle h-beam rods, ati super damper sfi balancer
prefer to sell as a full rotating assembly will part out if price is right.
local pick up only central nj
« Last Edit: December 14, 2013 - 09:25:03 PM by Davesrrcuda »
Offline Haddixj
Re: Mopar 72 340 plymouth cuda dodge challenger block
« Reply #1 on: December 02, 2013 - 09:15:54 AM »
Location may be helpful
Offline anlauto
« Reply #2 on: December 02, 2013 - 09:19:07 AM »
Should post the VIN too, just in case it matches somebodies car  :2thumbs:
It's cast in late 72 so most likely out of a 1973 car. :2cents:
Offline Davesrrcuda
« Reply #3 on: December 04, 2013 - 09:33:29 AM »
Item is located in the central nj area outside of Trenton
Offline Davesrrcuda
Re: Mopar 72 340 block plymouth cuda dodge challenger
« Reply #4 on: December 05, 2013 - 11:33:38 AM »
Rods sold!!!! 1300 or b/o for block and remainder.
Offline 4Cruizn
  • HEMI FISH
« Reply #5 on: December 05, 2013 - 12:50:08 PM »
73 was also balanced externally as stated it was . . .
Offline Davesrrcuda
« Reply #6 on: December 14, 2013 - 09:26:52 PM »
1100 or bo
Offline Davesrrcuda
« Reply #7 on: December 18, 2013 - 12:15:27 PM »
This is a fully balanced rotating assembly and fully machined. Block is .30 crank. .10 Pistons are je srp. I do have the eagle h beam rods to include which would be 550
Offline Davesrrcuda
« Reply #8 on: December 18, 2013 - 02:48:37 PM »
Stamping on block is 3b286592 for those trying to restore
