Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
Vacuum for Power Brake from Manifold or Carb ?
« previous
next »
Print
Pages: [
1
Author
Topic: Vacuum for Power Brake from Manifold or Carb ? (Read 1099 times)
LukeSkywalker
Jr. Member
Plymouth
on:
December 02, 2013 - 06:27:11 AM »
I've got a Holley street Dominator manifold with a 4 port carb (Holley Avenger 4150 870cfm el.choke).
Where do you get your Power Brake Vacuum from? Manifold vac intake or Carb vac intake?
Is there a difference?
Currently I have mine connected to the manifold intake.
Logged
Bullitt-
Permanent Resident
Better Things To Come Member Since 2/16/06
Re: Vacuum for Power Brake from Manifold or Carb ?
Reply #1 on:
December 02, 2013 - 06:57:49 AM »
Manifold vacuum for power brakes.....I have seen carbs that have manifold vacuum in the baseplate but most manifolds have a nipple or place for a nipple for the purpose.
Logged
Wade 73 Rallye 340..'77 Millennium Falcon...13 R/T Classic
Huntsville, AL
Chryco Psycho
Administrator
C-C.com Guru
Reply #2 on:
December 02, 2013 - 08:50:39 AM »
I agree , the brakes draw off the manifold , it will not affect any given cylinder where the vaccum is drawn from , the PCV should connect to the carb base so it is distributed to all cylinders evenly .
Logged
72cudamaan
Resident
Reply #3 on:
December 02, 2013 - 08:52:10 AM »
Definitely manifold vacuum. You want it unmetered so that you have as much as possible to utulize. As Bullitt said, the
nipple at the base of the carb works, or a port on the manifold.
Logged
If I cant fix it, it's broke
Andy (phukker whither)
LukeSkywalker
Jr. Member
Plymouth
Reply #4 on:
December 02, 2013 - 01:57:33 PM »
Ok. One less worry... Thanks guys.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
