Author Topic: 1970 Ralley Dash Wire Harness, RARE!  (Read 876 times)
Offline tuff340GranCoupe
« on: December 03, 2013 - 07:58:10 PM »
I have an original 1970 Ralley dash wire harness from a 70 Barracuda. This is correct for 1970 only with the correct 70 fuse box. There is no cuts or repairs to this harness, I have had it over 20 years in a plastic bag. Part number tag still in place yet reading: 2983830 . This is just the main harness, no defogger, a/c, power window, or stereo wires. Fuse box is decent for its age. I just retaped-up a few loose ends thats all. No melted or repaired areas that I see. Worked when pulled way many years back. This is the ideal harness for your 70 ebody as the repop harness is NOT correct & has the WRONG fuse block, so why bother with that one? If you change your cluster from a standard to a ralley dash, you will need this harness to correctly insure that everything will work right. Get the ORIGINAL harness and that counts on show day! I have many pictures, so if you want more, PM me ONLY with your email address & you can ask areas on the harness to see as well. Asking $400 but I am open to reasonable offers as well.
« Last Edit: December 05, 2013 - 06:16:50 PM by tuff340GranCoupe »
Re: 1970 Ralley Dash Wire Harness, RARE!
« Reply #1 on: December 05, 2013 - 06:17:14 PM »
Really? no takers? make offer?
