Author Topic: Tachometer or oil pressure gauge?  (Read 1795 times)
Offline Swedee
    • www.My72Challenger.com
« on: December 05, 2013 - 11:53:37 AM »
Hi all,
My '72 Challenger's gauge cluster has the silly cross thing on the far right, so I thought it might be a good idea to either put an oil pressure gauge or a tachometer there.
What would you guys say is the most useful?
Those clusters, like the one I have, are those different depending on whether it's a Rallye or not? I've seen the flashy ones with combined meters and stuff so I guess that's the case.
Thanks!
Check out my Challenger blog at http://blog.familjenjonsson.org/my72challenger/
Check out my blog at www.my72challenger.com
Offline 4Cruizn
  • HEMI FISH
Re: Tachometer or oil pressure gauge?
« Reply #1 on: December 05, 2013 - 12:46:38 PM »
Guess I would probably choose the oil pressure gauge . . . . :dunno:   If you don't have a temp gauge, that is always a good choice as well . . . .  :thumbsup:
Offline 74 challenge
« Reply #2 on: December 05, 2013 - 12:52:52 PM »
who makes a tach that fits that small hole and looks stock? is it a royal pain to install?
1-8-4-3-6-5-7-2
« Reply #3 on: December 05, 2013 - 01:11:30 PM »
I just did an oil pressure gauge conversion on my Dart.  I bought a 2" electrical oil pressure gauge and tore it apart.  I mounted the mechanism into the gauge cluster housing where the AMP gauge was originally.  I took the face off of the AMP gauge and screwed it to the oil pressure gauge.  The dash will still look stock but I'll have an oil pressure gauge and a low pressure light.
You might be able to do the same thing with your standard gauge cluster.  Do some measuring...you might be able to just mount the entire gauge in the existing hole.(that wouldn't look stock though)
« Last Edit: December 05, 2013 - 01:13:40 PM by burdar »
Offline Jamiez
  • Retro
« Reply #4 on: December 05, 2013 - 01:37:23 PM »
Rallye clusters have the tach, speedo, clock, and the 4 piece gauge (oil, temp, amps, fuel)
The empty spot on the standard gauge cluster (which is what is sounds like you have) was actually for a clock.
For a manual I might choose a tach over oil pressure, but it'd be a close call.
Depending on your budget, I do believe there are companies out there which will make you a multi gauge that fits into the spot.  It would be a one off custom job so bring your wallet  :money:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #5 on: December 05, 2013 - 02:39:19 PM »
I went Tach as pictured in the URL because I went with a standard 3 guage cluster for everything else like my other cars.
http://www.cuda-challenger.com/cc/index.php?topic=83942.msg877841#msg877841
I'm very vigilant on keeping an eye on things so everything runs smoothly.
B
Offline Swedee
« Reply #6 on: December 05, 2013 - 02:46:13 PM »
B
That looks really good! From where did you get it?
Since my mechanical skills are somewhat limited, I'm pretty sure that this should be something I should start fixing with AFTER next summer :)
Offline Swedee
« Reply #7 on: December 05, 2013 - 02:48:06 PM »
Sorry, I read now that you got it from VDO!
Offline edl94
  • She Cuda
« Reply #8 on: December 05, 2013 - 05:17:43 PM »
You can get this tach from year one. Perfect fit works well but a little hard to see due to its position and size.
« Reply #9 on: December 05, 2013 - 07:24:32 PM »
Is it possible to switch the gauges around? You could put the tach right next to the speedo and move the amp gauge to the end.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #10 on: December 05, 2013 - 10:23:15 PM »
As I remember it, it isn't that easy...
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
« Reply #11 on: December 06, 2013 - 12:02:27 AM »
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
Offline edl94
  • She Cuda
« Reply #12 on: December 06, 2013 - 12:31:40 AM »
To hard to switch them around. I would have but it would not work.
« Reply #13 on: December 09, 2013 - 10:30:33 AM »
How hard was this to do and how much dissasembly? I ask because I am good an engine work but wiring it not my strongest automotive skill. I am very interested in a tach.
1-8-4-3-6-5-7-2
Offline HP_Cuda
  • Mopar or No Car!
« Reply #14 on: December 09, 2013 - 12:14:00 PM »
Disassembly of the guages was very straightforward and there was only 2 screws holding the blanking plate in.
No problemo  :2cents:
