I replaced my driver side quarter window regulator which had a bad tooth, but other than that the window had aligned perfectly before I started messing with it.
Now I can't get the window to tip out as far as it should. It needs at least another 1/2in to fit into the top weatherstrip.
I have the bottom adjustment in as far as possible and the top is out as far as possible. Everything is in its proper slot.
I've been using the shop manual and also other pics that have been posted in these forums on how to adjust it. Any ideas on what I'm missing ?
Also.... my old regulator and the good used one I bought did not have a cam stop. Should I get one ?
