Author Topic: 1 bolt or three bolt  (Read 784 times)
« on: December 07, 2013 - 03:29:19 PM »
What is the difference between a 1 bolt and a three bolt cam? Just the timing gear attachment? Why are there two types? Is there that much resistance to turning a cam that it needs three bolts cuz of higher spring pressures needed for more radical cams?  :clueless:
Re: 1 bolt or three bolt
« Reply #1 on: December 07, 2013 - 07:47:42 PM »
Big difference , all performance engines used the 3 bolt design , 1 bolt in the center & a pin is not a lot of strength , trying to shear off 3 bolts + a pin is a lot stronger , especially when you get into high lift or roller cams with killer spring pressures .
 Most cam companies offer to grand any cam on 1 or 3 bolt at no extra charge so I always order 3 bolt
Offline Jesus H Chrysler
« Reply #2 on: December 08, 2013 - 10:19:04 AM »
 :iagree: I had a slant six, of all things, shear the cam pin and torque the cam bolt till it broke.  Found the top timing gear sitting on the bottom one in a nest of it's own chain.  Thankfully I haven't seen it on any other engine.  Yet.
Yes I own a 1972 Dodge Challenger Convertible T/A S/E with a 440 Six Pak. Can it get any more wrong?
{OO /===\ OO}
(OO==> <==OO)
Greg, in the middle of MA has:
1970 Dodge Coronet 440 "Zom Bee"
1972 Dodge Challenger convertible 440 5 speed.
1973 Dodge Challenger 318 "Brown Bomber"
2012 Dodge Challenger R/T Classic Blackberry Pearl.
2001 Jeep Wrangler locked, lifted and lighted.  "Jeep is a registered trademark of Chrysler Corporation"
