Author Topic: Fuel gauge reads 3/4 full when tank is full ???  (Read 3792 times)
Offline 351c4v71
« on: December 08, 2013 - 12:06:25 PM »
My fuel gauge reads 3/4 full when tank is full ???
Where do I start the testing??
Thanks
Offline blown motor
Re: Fuel gauge reads 3/4 full when tank is full ???
« Reply #1 on: December 08, 2013 - 12:27:38 PM »
Mine does the same thing. I know my gas tank was replaced. Not sure if that has something to do with it. Looking forward to the answers.
Offline 4Cruizn
  • HEMI FISH
« Reply #2 on: December 08, 2013 - 12:34:20 PM »
I think you will need to pull the tank and adjust the float on the sending unit until it reads full.  :eek4:
Offline farmboy70
« Reply #3 on: December 08, 2013 - 01:14:59 PM »
IF the sending unit is a repop, they are calibrated wrong for Mopars.
The ohms are wrong for Mopar gauges.
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #4 on: December 08, 2013 - 06:56:19 PM »
I have heard adding 50 ohm resister is the fix,
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline 351c4v71
« Reply #5 on: December 08, 2013 - 06:58:33 PM »
Mopardave,
How do I go about doing that exactely?
I know next to nothing about electrical.
« Reply #6 on: December 08, 2013 - 07:10:18 PM »
Mopardave,
 :popcorn: me too?
« Reply #7 on: December 08, 2013 - 10:51:41 PM »
put a 50 ohm resistor in line between the guage & sender , should cost less than $.25 at an electronocs store , if 50 ohm is correct sounds high to me but it might work OK
Offline HP_Cuda
  • Mopar or No Car!
« Reply #8 on: December 09, 2013 - 12:39:53 PM »
Was going to say head to digikey but here is one that should be close to everyone:
http://www.radioshack.com/product/index.jsp?productId=2062292
Or if you are good enough you can make your own - might take a bit of time to get the correct length of wire.
Offline dutch
« Reply #9 on: December 09, 2013 - 01:01:33 PM »
could be you float as well. They often leak and fill with gas
*** Bart ***
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #10 on: December 09, 2013 - 01:11:17 PM »
as CHRYCO said, in line. i personally have not , but it makes sense. I got this info from a customer.
Mopar Dave
73 F8 Challenger
1990 XJ - sold
« Reply #11 on: December 09, 2013 - 03:44:14 PM »
Dave,
  I'm not following the logic here.
If you short the blue wire from the sending unit to ground, the gauge will read full. Adding a resistor will only make it more inaccurate in this case.
The standard Mopar sending unit measures about 12 Ohms full, and 70 Ohms empty.
I would suggest trying to bend the arm with the float of your sending unit downward a bit.    :2cents:
Offline Jamiez
  • Retro
« Reply #12 on: December 09, 2013 - 04:17:57 PM »
If you do add a resistor, I'd recommend adding a variable one or a potentiometer.  They are more expensive but it would allow you to tune it have the gauge read exactly what you want.
