Author Topic: Fuel Line Question!!  (Read 1088 times)
Offline jmartin99
« on: December 09, 2013 - 10:23:24 PM »
I am putting together a '72 Challenger that has a 340 with Edelbrock heads and aluminum intake and also has Edelbrock 9913 carb. The owner wants a stainless steel line from the pump to the carb. Surely someone has done this before. I cannot seem to find a line for this setup. Would the line for a Thermoquad work? If so would I need an adapter fitting that would replace the inlet on the carb?   :working:
Thanks!  :cheers:
Jeff
Re: Fuel Line Question!!
« Reply #1 on: December 09, 2013 - 10:32:48 PM »
You would need an inverted flair fitting on the carb to use Thermoquad OE style line.  I see Summit sells a brass fitting.
Offline cudabob496
« Reply #2 on: December 10, 2013 - 05:04:39 AM »
http://www.edelbrock.com/automotive_new/mc/carbs_acc/access_fuel_filters.shtml
look at part #8102 above,  near bottom of page. Might work if can't find what looking for.
also
http://www.ebay.com/itm/like/310762536316
« Last Edit: December 10, 2013 - 05:07:02 AM by cudabob496 »
2011 Kawasaki Z1000
Offline jmartin99
« Reply #3 on: December 22, 2013 - 10:43:54 AM »
Well, I bought the edelbrock inverted flare fitting for the carb and then found the OEM Stainless line from Fuel Pump to carb. I received the line and it is nowhere near long enough to reach the inlet of the carb.
Has anyone ever put an edelbrock intake and carb on their small block?  If so, what did you do for the fuel line?
I think I will go to the local auto parts stores today to see if I can find a stainless line and bend it myself. I bet Stainless line is harder to bend than plain steel line.
Thanks for your input!
Jeff
Offline Strawdawg
    • Vortex Buicks
« Reply #4 on: December 22, 2013 - 11:15:52 AM »
Jeff
I am guessing it will be easier....
« Reply #5 on: December 22, 2013 - 11:34:09 AM »
What are your plans for a fuel filter? adding an in-line may gain the length needed.
I "engineered" the rubber hoses out of mine with a filter similar to this marine unit.
http://www.marinepartssource.com/partdetails.asp?pnumber=41425971&cat=30&catname=Inboard%20and%20I/O%20Engine%20Parts&sub1=4&sub2=16&sub3=0&subcategory=Chrysler&subcategory2=Fuel%20Filters&subcategory3=&mfgno=4142597-1
Offline cudabob496
« Reply #6 on: December 23, 2013 - 02:29:40 AM »
2011 Kawasaki Z1000
