I agree with using adjustable rocker arms any time, regardless of lift, so to get the best/accurate pre-load on the hyd lifter.
A more critical concern, in my opinion and experience, is the final choice of pushrod.... the overall length is the issue. I forget where I purchased my last set (maybe from Hughes?), but the length was correct at 7.25" (or a tad less... 7.23"?)... anything longer (for hyd lifters) makes the allowable remaining threads questionable, as well as the cup of the top of the pushrod possibly hitting the underside of the rocker arms.
I'm experienced only using the factory T/A rocker arms, and also the factory 273 rocker arms. I know there are some companies advertising such pushrods, for adj rkrs and hyd lifters, at a length of ~7.3125 and longer at 7.375, and those are both too long which allows too little remaining threads and the cup hitting the underside of rocker arm. It becomes worse if the heads have been cut, and/or using a thinner head gasket, as well as if the block deck has been cut (to square the block). (Note: I've always used the Fel-Pro #1008 performance head gaskets, compressed to ~0.038-0.040... I was a past Fel-Pro engineer so I've always used only Fel-Pro.)
Also, I believe the original factory T/A hyd lifters were slightly different than the standard hyd lifters... the T/A lifters had a deeper recession for the pushrod to seat its into the lifter, therefore, a T/A pushrod lengths were slightly longer at ~7.3125 (or 7.375) and only functioned properly with the matching factory T/A hyd lifters. However, those special-design T/A lifters have not been available for probably 30+ years. The result of the other comopanies offering those longer pushrods (7.3125 or 7.375) for use with adj rkrs and hyd lifters becomes the issue I'm explaining.
Long story short... the length of the pushrods is critical. Beware of trouble using pushrods of 7.3125 or 7.375 that are advertised to use with hyd lifters and mech rkr arms.
Happy holidays!
