Author Topic: Interior roof brackets  (Read 1407 times)
Offline 72cudamaan
« on: December 12, 2013 - 08:58:56 PM »
Any chance someone has pictures of the roof interior? I need pic's of the shoulder belt clips and coat hook locations. I
was dumb enough to put the headliner in without marking their location. Thanks for helping out the dumb guy.   :smilielol:
If I cant fix it, it's broke
Andy  (phukker whither)
Offline anlauto
Re: Interior roof brackets
« Reply #1 on: December 12, 2013 - 09:24:38 PM »
The "V" shaped brackets (PARTS IN THE BACK ROW) for the shoulder belt clips go under the headliner....If you don't have them in place, you're pretty much SOL and will need to let the headliner down again to install first.
If they are in place, you should be able to feel around for them.
« Last Edit: December 12, 2013 - 09:27:44 PM by anlauto »
Offline anlauto
« Reply #2 on: December 12, 2013 - 09:28:49 PM »
Good luck on the coat hangers. Might be better off to redrill a new hole :2cents:
Offline 72cudamaan
« Reply #3 on: December 12, 2013 - 10:27:08 PM »
Uh  Ohh.....Ohhhh Noooooo.
Offline farmboy70
« Reply #4 on: December 12, 2013 - 10:41:21 PM »
Are you looking for headliner installed pictures or bare roof pictures?
Offline 72cudamaan
« Reply #5 on: December 13, 2013 - 08:34:44 AM »
Pictures that show the location of the brackets and hooks installed. Unless it will become obvious when the headliner
gets pulled down.
Offline farmboy70
« Reply #6 on: December 13, 2013 - 09:44:23 AM »
gets pulled down.
If you didn't install the brackets you should see the mounting holes when headliner is released.
Anyway here are a couple of pictures with headliner installed.
The coat hook is at the edge of the headliner board and should be easy to find.
The pictures are from a 71 Cuda though.
Offline 72cudamaan
« Reply #8 on: December 13, 2013 - 12:03:34 PM »
 Thanks Dave.   :2thumbs:   I see the two brackets in the front and middle. What is holding up the buckle at the rear?
I know...I know, so many questions and so little time.  :smilielol:
Offline farmboy70
« Reply #9 on: December 13, 2013 - 12:38:16 PM »
Bolt under cover. You should be able to feel the hole thru the headliner material.
A little easier way to do a headliner is to put all the screws and bolts back in the holes before installing the headliner.
This way you can feel the screw heads and back them out thru the material instead of hunting for them afterwards.
Offline 72cudamaan
« Reply #10 on: December 13, 2013 - 12:44:31 PM »
Thanks again Dave.  I think I'm gonna start pulling down the headliner now. Suggestions taken. Wish me luck.
Offline jordan
« Reply #11 on: December 14, 2013 - 10:54:45 AM »
I would like to see a bare roof interior picture.  My headliner is installed with no seat belts.  I want to use a modern belt with a drop hanger.  I can feel what I think is the bolt hole, but after looking at all those brackets, I want to be sure it is a threaded hole and not just a hole so that I don't put an unnecessary hole in my headliner where I don't have to.  Thanks guys.
Offline farmboy70
« Reply #12 on: December 14, 2013 - 04:55:26 PM »
Here are a couple but they are from a 1970 Challenger.
Offline anlauto
« Reply #13 on: December 14, 2013 - 05:01:01 PM »
There's really only one hole that size in that area....as you can see in the above pictures...
Offline jordan
« Reply #14 on: December 16, 2013 - 12:37:54 AM »
That is exactly what I needed to see.  Only one hole.  Kind of hard to screw that one up.  Its good piece of mind to see what is under my headliner before I go poking holes in it.  Thanks
