Author Topic: needing info for a driveshaft on a 69 superbee, 4 speed, and 8 3/4 rear  (Read 3803 times)
Offline Andy Curnes
Needing length, diameter and u joint sizing if at all possible for a 4 speed. 8 3/4 rear end to fit a 1969 coronet superbee. Thanks
Offline Katfish
  • 70 Challenger
Offline 72bluNblu
Re: needing info for a driveshaft on a 69 superbee, 4 speed, and 8 3/4 rear
« Reply #2 on: December 13, 2013 - 02:10:37 PM »
That chart is close, but there is definitely some info on there that's questionable for some of the makes/models.
Is the car assembled? The easiest thing to do is measure. If you have a transmission yoke, push it all the way into the transmission, then pull it back out 1" and measure from the center of the u joint loop on the transmission yoke to the rear axle yoke. You're measuring from where the center of each u joint would be. This should be done with weight on the suspension, as that will change the measured length. Most folks use the center-center length, so you can use that dimension to either find the correct length driveshaft or to have one made or shortened.
As far as u-joint size, anything stock should be 7260 or 7290. 7260 is 2.125" across, 7290 is 2.625" across.
I just had a driveshaft shortened for the 8 3/4 swap on my Duster, the measured length was 49 1/4" c-c, which you will not find in that chart for a 340/833, 8 3/4 Duster/Demon.
Offline Andy Curnes
« Reply #3 on: December 13, 2013 - 11:24:55 PM »
Thanks guys for the info.  Of course the engine, and 4 speed are both out, and kind of left with some questions here and there.. It always amazes me how many people take these things apart and don't have a clue where they put parts, and peaces.  I wonder where all these parts disappear to.  The radiator is another peace that ended up being lost too.
Offline moparcardave
« Reply #4 on: December 15, 2013 - 08:24:22 PM »
I found this information on another post here in the forum
2852162 1968 3.00 52.07 727/833 8-3/4 383 426 440 Coronet Charger
Along with it they had the following, hope it helps.
Mopar Driveshaft length.This is a chart of common 1966 and later RWD Mopar slip yokedriveshafts. It is sorted by length to help with interchange.
Mopar Slip Yoke Driveshafts PartNo Years Dia" Length" Trans Rear Engine Body
2883775 1970-71 3.25 42.60 727,833 9-3/4 426 440 Barracuda Coronet
2996134 1974 3.25 43.29 727,833 8-1/4 318 360 Barracuda
2883636 1970 3.25 43.60 727 8-3/4 383 426 440 Barracuda Coronet
2996134 1971 3.25 43.79 727/833 8-3/4 340 Barracuda
2883769 1970-71 3.25 43185 727/833 8-3/4 340 Barracuda
2883667 1970-71 3.25 44.60 727/833 9-3/4 426 440 Challenger Coronet
2883690 1970-72 3.00 44.99 727 8-3/4 340 Duster Demon
2883656 1970-71 3.25 45.60 727/833 8-3/4 340 383 440 Challenger
2996142 1971 3.25 45.79 727 8-3/4 340 383-2 Challenger
2883782 1970 3.25 45.85 727/833 8-3/4 340 Challenger
3578138 1974 3.00 47.40 904/230 8-1/4 318 Barracuda
2852228 1967-69 3.25 47.81 727 8-3/4 340 383 Dart
2883693 1970 3.25 47.99 727 8-3/4 340 Dart
2852206 1967-69 2.75 48.60 904 8-3/4 273 318 Barracuda Valiant
2852206 1967-69 2.75 48.60 833 8-3/4 273 318 340 383 Barracuda Valiant
2852216 1968-69 3.00 48.88 727 8-3/4 340 393 Barracuda
2996157 1972 3.25 48.89 904/230 8-3/4 225 318 Duster Demon
2883760 1970-72 2.75 48.96 833 8-3/4 340 Duster Demon
2883760 1970-72 2.75 48.96 904 8-3/4 198 225 318 Duster Demon
2883752 1971 2.75 49.27 904/833 8-3/4 198 225 318 340 Valiant
3578146 1973 3.00 49.40 727/833 8-3/4 318 340 Challenger
2996105 1971 3.25 49.50 727/833 9-3/4 426 440 Belvedere Coronet
2781952 1966 2.75 49.58 904/833 8-3/4 170 225 225 273 Barracuda Valiant
2996146 1971-73 3.25 49.89 727/833 8-3/4 318 340 Challenger
3467151 1973-76 3.25 49.90 904/833 8-1/4 225 318 340 360 Duster Dart Sport
2883779 1970-72 3.25 49.95 727 8-3/4 318 Challenger
2883766 1970 3.25 50.18 727 7-1/4 225 318 Barracuda
2781955 1966-67 3.00 50.27 833 9-3/4 426 Belvedere Coronet
2853247 1968-69 3.00 50.39 833 9-3/4 426 440 Belvedere
2996101 1971 3.25 50.68 727/833 8-3/4 383 426 440 Belvedere
