Author Topic: Cleaning dash trim pieces  (Read 4538 times)
Offline usraptr
Re: Cleaning dash trim pieces
« Reply #30 on: January 04, 2014 - 11:14:24 PM »
Those metal clips were masked off with painters tape prior to painting and it has sense been removed.
 BTW, I used the SEM Black Landau for the metal trim pieces as well.  Came out like new.
(Edited 8-1-17)
Offline Racer57
« Reply #31 on: January 05, 2014 - 08:39:03 AM »
Sorry to hijack... whats the large round holes purpose in the rear side panels lower back corner ?  Breather ?
Offline HP_Cuda
  • Mopar or No Car!
« Reply #32 on: January 05, 2014 - 12:59:16 PM »
The one in the middle is for the window crank but I'm sure you figured that out, the one below that actually gets covered up by the lower portion of the seat so....hmmm
Offline jimynick
« Reply #33 on: January 05, 2014 - 11:00:52 PM »
It may be for the seat belt anchor.
Offline burdar
« Reply #34 on: January 06, 2014 - 08:59:07 AM »
If I remember correctly, that hole is there so you can access the lower 1/4 window mounting/adjusting bolt.(possibly for fine tuning the window after the trim is installed.
Offline usraptr
« Reply #35 on: January 07, 2014 - 12:21:49 AM »
Rear seat belt mounts to body through those holes.
(Edited 8-1-17)
