Author Topic: different way to fit large tires on a cuda  (Read 762 times)
Offline halle09
« on: December 14, 2013 - 11:21:51 PM »
found this tonight just looking online. figured it would help someone out who doesnt want to but a b body rear for fitment
http://www.moparts.org/Tech/Archive/rearsusp/12.html
Re: different way to fit large tires on a cuda
« Reply #1 on: December 15, 2013 - 10:30:08 AM »
The springs are biggest impediment to fitting larger tires. Obviously, cutting perches and rewelding them on the original E body housing accomplishes the spring movement. The easy aspect of using a B body housing is it avoids all the cutting and welding involved with converting an E body housing.  It also will require a different offset of the rims between the two options as well.
Offline 69CHARGERMD
« Reply #2 on: December 15, 2013 - 03:38:59 PM »
Good link.
I am going to a b body Dana in mine, want to beef things up and get a bigger tire.
Some to dr diff, and he has it all worked out already and was a great resource.
1970 Challenger WSS
1969 Charger RT/SE
1965 Belvedere
