Author Topic: 1970 Challenger 15" rims  (Read 7136 times)
Offline Dr. Feelgood
  • 1970 Challenger R/T #XXX666
« on: December 16, 2013 - 11:39:29 AM »
Just about to take advantage of YearOne's 25% off sale and order a set of 15" Rallye rims.
Does this look right?
Fronts:
Part Number: FP90C Reproduction Chrysler Rallye wheel,
15"x7" with 5-4 1/2" bolt pattern. 4 1/2" backspacing.
This reproduction 15" x 7" Rallye wheel has the correct OEM offset to the inside to accept the original-style 15" trim ring. Sold individually.
Rears:
Part Number: FP90E Wheel Vintiques Chrysler Rallye wheel,
15"x8" with 5-4 1/2" bolt pattern. 4 1/2" backspacing.
Color : Silver Powder coat silver finish. Uses factory style lug nuts, center caps, and trim rings which are not included.
Re: 1970 Challenger 15" rims
« Reply #1 on: December 16, 2013 - 11:49:13 AM »
Yep, found the sticky thread up there: http://www.cuda-challenger.com/cc/index.php?topic=19470.675
Just double checking before I pull the trigger
Offline HemiOrange70
« Reply #2 on: December 16, 2013 - 12:53:47 PM »
thats what I  run
« Reply #3 on: December 16, 2013 - 01:33:59 PM »
thats what I  run
Perfect! Thanks :D
Didn't know this but the center caps need these self tapping screws in order to stay on? They don't stay on by the lugs?
Part Number: FD919020 Rallye wheel caps screws, set of 20.
Wheel cap screw sets-These self-tapping screw kits are for both Magnum and Rallye wheel caps. Use 5 per cap.
https://www.yearone.com/Product/1966-74-a-b-e-body/fd919020
« Last Edit: December 16, 2013 - 01:52:39 PM by Dr. Feelgood »
Offline anlauto
« Reply #4 on: December 16, 2013 - 02:10:32 PM »
Perfect! Thanks :D
NO they do not stay on with the lug nuts...you MUST screw them on from behind. :2cents:
« Reply #5 on: December 16, 2013 - 02:40:54 PM »
Thanks! Really appreciate the reply/info :D
Offline KillerBee
« Reply #6 on: December 16, 2013 - 07:15:28 PM »
15x8 will work on the front too.
I have 15x8's all around on my 71 R/T Challenger.
All 4 are 15x8 with 4 1/2 backspacing.
245/60-15 tires on the front....
275/60-15 tires on the rear.....
No rubbing anywhere.
« Last Edit: December 16, 2013 - 07:26:52 PM by KillerBee »
Offline Lotsapins
« Reply #7 on: December 23, 2013 - 09:47:46 PM »
But your car is a mile up in the air. you have it jacked up all the way around to fit the big tires and the 8"rims. You can see daylight between the tires and fender. Beatiful car, but it sits too high.
Thanks , Keith
71 Challenger Conv
Build Thread: http://www.cuda-challenger.com/cc/index.php?topic=97569.0
71' Roadrunner Stock restored 383 4spd
08 Charger SRT8 Super Bee
07 Ram 2500 4WD Cummings
« Reply #8 on: December 24, 2013 - 08:52:36 AM »
That's the same ride height I'm after. I think it looks like the same height as a T/A no? :dunno:
Looks great!
Offline Lotsapins
« Reply #9 on: December 24, 2013 - 10:29:15 AM »
Looks great!
Well there ya go. Start cranking those torsion bars and get some air shocks or stiffer springs and you too can get up there.
And no ... T/A and AAR's didn't stand that high.
Thanks , Keith
71 Challenger Conv
Offline HP_Cuda
  • Mopar or No Car!
« Reply #10 on: December 24, 2013 - 02:14:22 PM »
I've seen many folk say that on 15x8's in the front they run a 245/60-15 tire and they all don't sit at that height.
Or do they?
 :popcorn:
Offline HP2
« Reply #11 on: December 24, 2013 - 02:28:26 PM »
I run 15x8 on the front of my Challenger and use the equivalent of a 255/50 tire and my ride height is so low the tire sidewall sits half way up inside the wheel opening.  It all depends on what you want to run and how you want it to sit.
Offline 72cudamaan
« Reply #12 on: December 24, 2013 - 04:39:01 PM »
Says you!  I think it looks good, says me.  :stirpot:
If I cant fix it, it's broke
Andy  (phukker whither)
Offline KillerBee
« Reply #13 on: December 26, 2013 - 02:58:28 PM »
Really?
You can see daylight between the tires and fenders? :clueless:
Here is a pic of the same car (without it's engine) with the same factory rear leaf springs with factory 14" wheels.
I think it looks terrible with those dinky little wheels/tires on it :puke:
Here is a picture of an original T/A Challenger on original 15" tires....lots of daylight on that jacked up car?
When I first put my new wheels/tires on the car I experimented with the car sitting both high and low in the front and took lots of pics.
I tested it with the front sitting very low(no rubbing anywhere) but I hated the look. :grinno:
My car is definitely not jacked up.
I don't have air shocks on it and the rear leafs are the originals.
The front torsion bars are adjusted very soft and the front is NOT stiff at all.
There is no right or wrong wheel/tire combo, whatever makes the owner happy is the best answer.
If someone is looking to put the biggest 15" wheel/tire on the front of a Challenger without jacking it up or rubbing the 15x8 with 4 1/2 backspacing and 245/60-15 tire is an excellent choice.
I like my car sitting lower with the body covering just the top of the tires but NOT on the ground like a ricer with half the tire covered up.:2cents:
« Last Edit: December 26, 2013 - 04:04:41 PM by KillerBee »
« Reply #14 on: December 27, 2013 - 02:18:29 PM »
Exactly what I was thinking/seeing KillerBee
IMO you got the perfect ride height and I don't see any difference in comparison to the height of a T/A.
Nice work!
