Author Topic: Need help with where these insulation pieces go  (Read 579 times)
Offline usraptr
« on: December 16, 2013 - 11:55:43 AM »
I'm in the process of putting the insulation back under the dash of my '70 'Cuda.  I've got most of it back in but I neglected to mark down where these three pieces went and can't figure it out.  Any help would be greatly appreciated as to where they go.
Thanks in advance.
(Edited 8-1-17)
Offline HP_Cuda
  • Mopar or No Car!
Re: Need help with where these insulation pieces go
« Reply #1 on: December 16, 2013 - 01:24:49 PM »
The pieces go behind the heater box and the drivers side air vent
« Last Edit: December 16, 2013 - 01:26:49 PM by HP_Cuda »
Offline shoooter
« Reply #2 on: December 16, 2013 - 01:44:39 PM »
How do they go on? Clips?
Offline Skunkworks Challenger
  • Mopars forever!
« Reply #3 on: December 16, 2013 - 01:55:26 PM »
They are fastened by plastic nails (pins) that push into holes in the firewall.
The Brewmaster
Offline HP_Cuda
  • Mopar or No Car!
« Reply #4 on: December 16, 2013 - 02:25:05 PM »
Those pins are a pain in the butt.
You need to be careful when pounding them in as they break easy, then you get to start all over again.
 :bigsmile:
Offline usraptr
« Reply #5 on: December 16, 2013 - 02:31:35 PM »
HP_Cuda, are you sure?   I already have insulation pads in those areas and don't see any room for additional pads.  Please see attached pics. I was thinking maybe over the access holes to the door hinges in the "A" pillars, see pics?
(Edited 8-1-17)
« Reply #6 on: December 16, 2013 - 03:24:26 PM »
Check and see if they fit on the back side of the kick panels.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #7 on: December 16, 2013 - 05:20:03 PM »
Yeah I went back and looked at mine, they do look like kick panel insulation pieces.
Haven't stuffed mine in yet, have to still stick the dash in.
 :working:
Offline usraptr
« Reply #8 on: December 16, 2013 - 05:51:28 PM »
The larger piece definitely goes behind the passenger kit panel and covers the hold in the A frame where you access the door hinge bolts.  When I dug out my driver's side kick panel it already had a insulation pad on the back side to cover the A frame hole on the driver's side so I'm still trying to figure out where the other two smaller pads go.   :clueless:
(Edited 8-1-17)
