Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Audio
(Moderator:
Chryco Psycho
Audio system cuts out
« previous
next »
Print
Pages: [
1
Author
Topic: Audio system cuts out (Read 2534 times)
Mikey340
Jr. Member
on:
December 18, 2013 - 11:29:27 AM »
I am having a problem with the sound system in my Cuda. Whenever I try to turn up the volume the unit cuts out. I suspect a voltage problem; like the stock alternator doesn't have enough output.
Any ideas would be appreciated.
Thanks,
Logged
inviolet
Jr. Member
Re: Audio system cuts out
Reply #1 on:
December 18, 2013 - 11:45:01 AM »
If your running an AMP try a thicker gauge wire to Amp and to Ground of Amp. Some Amps call for 4 gauge wire. Check the specs.
Logged
Katfish
Resident
70 Challenger
Reply #2 on:
December 18, 2013 - 12:55:01 PM »
Did you run a dedicated power feed to amp directly from battery?
Logged
Mikey340
Jr. Member
Reply #3 on:
December 18, 2013 - 02:32:25 PM »
It already has a heavy gauge wire that is wired to the battery. I am using a yellow top Optima battery.
Logged
dave73chally
Sr. Member
Reply #4 on:
December 18, 2013 - 02:38:28 PM »
Check your grounds, make sure it is grounded to a clean metal surface. A poor ground will cause a voltage spike when you crank up the volume causing your sound to cut out.
Logged
73 Challenger
momack55
Jr. Member
Why are you laughing? Mary! Well tell me! Tell me!
Reply #5 on:
December 22, 2013 - 07:04:22 PM »
Having the same problem!!
Am attacking the bad earth theory first!
I'll keep ya posted!
Mozz in Oz!!
Logged
Person to person call for Kowalski. Can ya hear me Kowalski?
422STROKER
Sr. Resident
Member Since 6/3/06
Reply #6 on:
December 22, 2013 - 08:54:11 PM »
Do you have an Amp? If so, What type of speakers are connected to it and how do you have them wired?
Sent from my iPad using
Tapatalk
Logged
Tom
4Cruizn
Administrator
C-C.com Expert
HEMI FISH
Reply #7 on:
December 23, 2013 - 12:16:56 AM »
How loud before it cuts out . . . My amps like to overheat . . .
Logged
edl94
Jr. Member
She Cuda
Reply #8 on:
December 23, 2013 - 01:13:17 PM »
Mine did the same thing found a bad speeker new out of the box (drawing to much power?) . Turn the balance and the front to rear fader crank it up and see if one of the chanels make it cut out.
Logged
inviolet
Jr. Member
Reply #9 on:
December 24, 2013 - 10:23:22 AM »
Inverted polarity on one speaker can also cause a similar issue.
Logged
MEK-Dangerfield
C-C.com Expert
I don't get NO respect! Member since 1/25/2002
Reply #10 on:
December 26, 2013 - 04:19:02 PM »
I think we need a little more info. My aftermarket amp sometimes kicks out when idling at a red light(alternator is turning too slow). Is your issue the same, or does it kick out while driving?
Logged
2016 SXT+. 1 of 524 SXT+'s in Plumb-crazy for 2016.
Mikey340
Jr. Member
Reply #11 on:
December 27, 2013 - 07:58:18 PM »
My system cuts out when I try to turn up the volume. I also have one door speaker that quit working; I am going to check the wire terminals and make sure they aren't backwards. I had it apart when I was insulating the door with some peal and seal.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Audio
(Moderator:
Chryco Psycho
