Author Topic: Re-Pinning console / glovebox locks? How To  (Read 1135 times)
Offline Katfish
  • 70 Challenger
« on: December 21, 2013 - 10:59:37 AM »
My trunk key doesn't match the console or glove-box locks.
So I'd like to take my existing working trunk key and adjust/modify the console & glove-box to match.
What's involved, is it possible to do this myself.  Any tips / suggestions are appreciated.
Thanks
Offline 4Cruizn
  • HEMI FISH
Re: Re-Pinning console / glovebox locks? How To
« Reply #1 on: December 21, 2013 - 11:13:06 AM »
Chryco will know . . . He was a locksmith at one point in his life!   :thumbsup:
Offline 72cudamaan
« Reply #2 on: December 21, 2013 - 12:10:07 PM »
I didn't know they had locks on Igloo's  :smilielol:
If I cant fix it, it's broke
Andy  (phukker whither)
Offline crash340
« Reply #3 on: December 21, 2013 - 04:15:19 PM »
hahah funny Andy, I matched my glove box lock the other day, was easy, but the console lock maybe a little different, it might be easier, once you get the glovebox lock out to either have a new key cut, cut your own blank then match your trunk lock.
Greg
73 Cuda
Brisbane, Australia
« Reply #4 on: December 21, 2013 - 10:16:07 PM »
On an igloo to pick the locks you use an ice pick LOL
 The hardest parts is getting the locks apart , on the glove box the lock has to be in the locked position & there is a small window to insert a paperclip or similar into to depress the retainer to release the lock core , once the core is out there are wafers , Chrysler uses 6 different cut  heights , you can move them around & try to match the depths or if they sit too tall you can file them down a little to match the core diameter . If possible you really need a selection of wafers to replace the ones you need . the console lock is similar but comes apart differently .
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
« Reply #5 on: December 21, 2013 - 11:22:12 PM »
I had a same/similar problem (including door locks that didn't match the ignition key).  I bought an entire lock set for the car.  The glove box door lock was the most difficult to change out (as Chryco mentioned), especially since I didn't have a key for it.
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
Offline Katfish
  • 70 Challenger
« Reply #6 on: December 22, 2013 - 08:16:59 AM »
Good info, I'll play around with the console first since it sounds easier.
I have a couple of old door handles lock cylinders, are the wafers from these the same?
What's the trick to get the glove box cylinder apart without the correct key?
My key slides in, just won't turn it.
Offline tuff340GranCoupe
« Reply #7 on: December 22, 2013 - 01:14:27 PM »
I always wanted to know how to take aprt a glove box door lock. I remember way back in '81 when I had my Gran Coupe the door locks were worn out, so I had a different set of locks in the doors than the ignition, as well as the trunk & console. Funny I had a different key for each lock cylinder in that car, took me several years before I fixed that problem! :bigsmile:
« Reply #8 on: December 23, 2013 - 08:02:49 AM »
door lock cylinders use pins not wafers so no you cannot use parts from them .
You have to pick the lock to the closed position , I am not inclined to teach you how to do that on an open forum !!
 you could take the glove box door to a locksmith
