Author Topic: Pic of ESPO 1.5" over + 275 rear tires?  (Read 5266 times)
Offline dave73chally
« on: December 21, 2013 - 07:27:56 PM »
Looking for a picture of ESPO 1.5" over stock with 275/60 rear tires. I'm running this size tire and want to see the look before I pull the trigger on the ESPOs. I'm running 235/60 fronts and want a decent rake.
73 Challenger
Offline bentpshrods
  • Almost there, Boise Id.
Re: Pic of ESPO 1.5" over + 275 rear tires?
« Reply #1 on: December 22, 2013 - 11:56:41 AM »
   I like a car with a good rake to it also. I went with espo 1" over springs with poly bushings and have no complaints at all.  Have the same tire sizes and also run my battery in the trunk.   Don't know how much difference there is between a 1'' and 1.5" over spring ---- I would go with the 1.5 .   Springs have been on for about 6 years now.
Offline 422STROKER
  • Member Since 6/3/06
« Reply #2 on: December 22, 2013 - 12:46:31 PM »
That looks great Bentpushrods!
Tom
Sent from my iPad using Tapatalk
Tom
« Reply #3 on: December 22, 2013 - 02:52:37 PM »
Nice cuda, love those billboards with the louvers. Stance looks good, I'm thinking the 1.5" also, want a bit more rake to it.
73 Challenger
« Reply #4 on: December 22, 2013 - 03:00:21 PM »
Granted this is a roadrunner, I think this stance is perfect. Might be more than 1.5" over stock? Definitely will need to crank down the torsion bars in the front...
73 Challenger
Offline ff6849
« Reply #5 on: December 22, 2013 - 06:11:31 PM »
275/60/15 with ESPO +1
(__________]]]]]}~~~~
73 440 Cuda'
915 heads (mild head work, stock bottom end 10/9:1 compression)
A518 2600-2800 Stall
4.10 rear gear
TTI headers with 3' exhaust with  X pipe
comp XE274H cam
Hughes Roller Rockers
Holley Sniper EFI
Holley Street Dominator intake
MSD ignition
« Reply #6 on: December 22, 2013 - 07:38:12 PM »
Nice stance, what size fronts are you running?
73 Challenger
« Reply #7 on: December 22, 2013 - 07:49:59 PM »
Also notice, that if they wanted to, bentpshrods and ff6849could probably lower the nose more if they wanted to if you wanted more rake with the same rear springs they have.  :2cents:
Offline Road_Runner
« Reply #8 on: December 22, 2013 - 09:13:05 PM »
What size wheels & tires are you running?  Are those 8" front & 10" rims on the rear.  I've got 7" front / 8" back rallyes right now and I'm considering moving the 8" to the front and getting 10" for the back.  I also have stock height xhd ESPO springs to go on but waiting to do some floor pan work before I redo the suspension.
Thanks, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
Offline bentpshrods
« Reply #9 on: December 22, 2013 - 11:56:48 PM »
       dodj is right. I put a new front suspension kit in and when I had it alined I had the front end height brought up a bit to give me a little more header clearance. I could bring it down a bit for a little more rake.     RR--the wheels are 15 X 7 front (235/60)  and 15 X 8 rear (275/60)
Offline Road_Runner
« Reply #10 on: December 23, 2013 - 11:25:48 AM »
Exactly what I'm running except I've got 245/60s on the front.  Great looking car and love the stance, I hope I'm going to be as happy with my std height rear springs.  I thought you're front could be a bit lower too so maybe mine will still have a little nose down attitude with my setup.
Later, Jim
Offline Road_Runner
« Reply #11 on: December 23, 2013 - 11:28:06 AM »
Not being picky, just wanted to point out that's a Charger probably 71 not a Roadrunner.  Same basic shape so easy to confuse the two, and both great looking cars!
Later, Jim
« Reply #12 on: December 23, 2013 - 11:30:08 AM »
Ah yea you're right. The rear window of the charger comes to an almost point while the roadrunner is more rounded. Good eyes
73 Challenger
Offline ff6849
« Reply #13 on: December 28, 2013 - 02:10:19 PM »
ok newly installed wheels and tires 235/60/15 fronts 7inch rim and 275/60/15 with 8 inch rim
73 440 Cuda'
4.10 rear gear
comp XE274H cam
Holley Sniper EFI
MSD ignition
« Reply #14 on: December 29, 2013 - 09:01:49 AM »
72 Charger Ralley  if want to be really picky  :2thumbs:
