Author Topic: i bought my dream car! 73 cuda  (Read 3299 times)
Offline halle09
« on: December 21, 2013 - 11:21:03 PM »
OK guys ive been on the forum for a couple months now asking questions but her goes my car thread. I bought a 73 cuda in September. Everyone who knows im a car guy knows my dream way a cuda since i was 16. Finally got one!
The car: 73 cuda 416(none original motor) with a 4 speed(original)
car  has a 416 stroker all done new with 500 miles on it with j heads and a holley double pumper with a big hydro cam and 355 gears. power brakes(front discs) power steering. none AC .no rear sway bar. front end wiring harness is brand new when bought, it also have aftermarket auto gauge cluster oil, volts, temp and a tach
BODY: needs some tlc its autumn bronze....or S&%T brown which ever u prefer. Rust in rear quarters mostly in front of wheels as usual it needs some body work and a paint job but it is good enough to be tolerable for a year or so. Underneath is amazing. virtually no rust at all other than body. frame is in great shape if you look under it
What i want to do:
This is where i need your expertise. I would like the car to be a weekend car while still being super reliable and i would like to head in the direction of handling and brakes ,suspension etc. I said super reliable for a reason here because i would like to one day take the car across or halfway across the country some day (me and my buddy cruising to nowhere)so comfort and reliability is a must.,i would like to know what you guys think i should be doing first. swaybars? sub frame connectors? leaf spring? shocks? brake upgrade etc
What i have done and need to do:
replaced the old fuse box with a new blade fuse system i made. for ease and reliability
replaced the starter with a high torque mini starter.(New motor original starter...i didnt get it either)
new battery
new turn signal switch, ignition switch, and key lock cylinder
new radio and speaker-subwoofer etc.
i will be getting new nitto 555 tires and rims within a month or 2
i will be getting sound deadening/carpet and new jegs seats with side bolsters and recline for comfort since my buckets are torn and are basically highly uncomfortable
i would like to get a rev limiter also for security....recommendation?  pertronix inner distributor?
The journey begins.....please help i am open to all opinions and questions
« Last Edit: December 21, 2013 - 11:36:50 PM by halle09 »
Offline halle09
Re: i bought my dream car! 73 cuda
« Reply #1 on: December 21, 2013 - 11:34:17 PM »
more pics
Offline Cuda Cody
  • Vancouver, WA
« Reply #2 on: December 22, 2013 - 01:32:53 AM »
Looks real good!  Nice find!   :clapping:
Offline ChallengerHK
« Reply #3 on: December 22, 2013 - 03:08:13 AM »
Congratulations! How is the 416?
- Han Solo, Star Wars
Offline halle09
« Reply #4 on: December 22, 2013 - 09:09:00 AM »
its an animal...the guy didnt give me a official build sheet but he wrote out what he put in it
4 inch mopar 4 inch crank
eagle I beam rods
arp bolts
diamond race pistons .30 over
internal balanced
1/2 2.02 j heads (no port work)
stock rockers and pushrods
high volume oil pump
police car water pump
new mopar oil drive
shaft and bushings
new mopar harmonic balancer
new mopar flywheel
new engine wiring harness
mopar perf. dist.
cloyes double roller chain
Offline 422STROKER
  • Member Since 6/3/06
« Reply #5 on: December 22, 2013 - 12:56:28 PM »
Very nice, you'll enjoy the stoker!  BTW that's a vac secondary carb fwiw
Tom
Sent from my iPad using Tapatalk
Tom
Offline halle09
« Reply #6 on: December 22, 2013 - 02:26:04 PM »
Tom
so what does that mean? good or bad? i dont know what fwiw is
Offline 422STROKER
« Reply #7 on: December 22, 2013 - 03:03:27 PM »
For what it's worth. = FWIW
Depends on the final outcome, I run a vac sec carb on mine. It's very street able, Double Pumpers shoot more fuel no matter what when floored. Vac secondary gives it depending on engine vacuum.
Tom
Tom
Offline halle09
« Reply #8 on: December 22, 2013 - 06:49:37 PM »
Tom
oh ok i didnt know if you thought it was a bad thing with the set up for some reason....yea shes gunna guzzle gas either way but its a weekend car for the most part.
Any suggestions you guys can give about when to start as far as suspension brakes handling etc.???
Offline 74challenger03
« Reply #9 on: December 22, 2013 - 08:19:15 PM »
 :clapping: congrates on the car. Have fun
Offline 422STROKER
« Reply #10 on: December 22, 2013 - 08:46:49 PM »
Suspension, steering and brakes are a good start.  Do a search for These topics, lots of knowledge.  My car was built for what your looking for.  Has been very reliable for me over the years and have had many road trips over that time.
Tom
Tom
Offline 4Cruizn
  • HEMI FISH
« Reply #11 on: December 23, 2013 - 12:25:29 AM »
Welcome to the site!  Nice looking car!  Where are you located . . . If close to me, I probably have some parts that could help!    :thumbsup:
Offline TA Wanted
  • Im a Mopar Addict
« Reply #12 on: December 23, 2013 - 04:07:53 PM »
Looks like a great car keep us posted!!!!
Offline halle09
« Reply #13 on: December 23, 2013 - 05:42:55 PM »
long island
Offline cudamadd
    • cudamad157071@gmail.com
« Reply #14 on: December 29, 2013 - 12:04:39 AM »
Hi looks good , you know when some one tells you they brought  there dream car. And you then   know how much it means to them. This in its self keeps the hobby alive  . Here in Australia a few friends have waited and waited until they have found there dream car , and in doing so I think makes it just that  little more special .Well done in finding your car and  I hope you enjoy it ,with a big smile cheers :aussie:
Go 4 a spin Ya Why Not.
