Author Topic: Split seat seams bonded to foam?  (Read 768 times)
Offline dave73chally
« on: December 23, 2013 - 10:08:55 AM »
Ok, I'm in the process of removing my seat covers, they are split at the seams. Most of the seam threading is attached pretty firmly to the foam below. Was there glue placed on the seams after the covers were installed and possibly the glue melted due to heat and bonded the split seam edges to my foam? This is a real PIA....
73 Challenger
Offline 72cudamaan
Re: Split seat seams bonded to foam?
« Reply #1 on: December 23, 2013 - 08:53:47 PM »
Are you sure that what you're seeing isn't the seam still attached to the wire stays?
If I cant fix it, it's broke
Andy  (phukker whither)
« Reply #2 on: December 23, 2013 - 11:11:02 PM »
Aren't the wire stays only along the base of the cover? What I'm talking about is the seat bottom, the section where you'd sit. But I'm not sure, this is my first attempt at doing anything upholstery related...here's the best picture I have
73 Challenger
Offline 72cudamaan
« Reply #3 on: December 24, 2013 - 02:55:24 PM »
No, there are 2 heavy gauge straps in the upper cushion and the lower cushion. They help define the creases and are located about 3 inches in from either side.
« Reply #4 on: December 24, 2013 - 08:52:01 PM »
How do I go about separating the straps from the cushions?
73 Challenger
Offline 72cudamaan
« Reply #5 on: December 24, 2013 - 09:50:14 PM »
They are held in place with hog rings.
Offline Colorado-0A5599
  • Mopar or no car!
« Reply #6 on: December 25, 2013 - 04:09:17 AM »
 Here is a couple pics of Front seat.  :2cents:
My wife ?   O.K.
My dog ?    Maybe
My Dodge? NEVER!!!
