Author Topic: where do the horn relay wires go?  (Read 1108 times)
Offline halle09
« on: December 23, 2013 - 05:37:15 PM »
i have a 73 cuda and i replaced the fuse block with a modern one and because i didnt have a relay in it i did not know what the wires were for. so i put em together and left them. i want a horn obviously and i need to know on the relay itself what wires go where? i have a 3 prong without the key buzzer so if you are looking at it so it looks like this
(Dashes are the prongs themselves) what goes where IE?( 12volt constant,ground to steering wheel and to horns)...?
       Prong A  _
      Prong B _  _ Prong C
Offline HP_Cuda
  • Mopar or No Car!
Re: where do the horn relay wires go?
« Reply #1 on: December 23, 2013 - 08:24:35 PM »
i could tell you on the stock fuse block as I had to locate the wiper motor lead the other day ( I love it a plan comes together ) which is close to the horn but you will have to. Either post up a pic of refer to the instructions that came with the new fuse block.
Offline halle09
« Reply #2 on: December 23, 2013 - 08:51:45 PM »
i made my out fuse block without a horn relay socket..
i just need to know what wires go on which prong for example top prong is 12v constant bottom right is ground on the steering wheel and which is horn ...etc.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #3 on: December 24, 2013 - 01:48:57 PM »
If you look at this schematic (for a 73) then you would see it has a 4 prong horn relay:
http://www.mymopar.com/downloads/1973/73BarracudaA.JPG
Offline halle09
« Reply #4 on: December 24, 2013 - 07:10:20 PM »
Never mind i figured it out horns all goot to go thanks
Offline HP_Cuda
  • Mopar or No Car!
« Reply #5 on: December 26, 2013 - 12:55:02 PM »
 :2thumbs:
