Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Body Shop
(Moderator:
Chryco Psycho
Lower fender patch panel
« previous
next »
Print
Pages: [
1
Author
Topic: Lower fender patch panel (Read 613 times)
acudadude
Jr. Member
on:
December 24, 2013 - 11:41:02 AM »
Hi Guys, A question for you body work guys i have these old lower fender patch panels and would like to know if they should be butt welded or overlap welded? Also should i use the whole patch or cut it at the body seam in the fender or below the seam ? Does anyone know what gauge these are; there old parts? Have not removed the fender yet but what do you do for the inside bracket if it rusted out? Thanks for any help!!!
Logged
Edison1970
Jr. Member
Re: Lower fender patch panel
Reply #1 on:
December 24, 2013 - 12:27:27 PM »
I butt welded mine. Only use as much as you need. If the metal is bad only six inches up, cut out 6 1/4".
As far as the brace, you really can't tell until you cut the top skin off. Save it if you can. AMD patch panels come with
part of a brace.
Logged
72cudamaan
Resident
Reply #2 on:
December 24, 2013 - 04:40:13 PM »
Butt weld.
Logged
If I cant fix it, it's broke
Andy (phukker whither)
anlauto
Permanent Resident
I'm Alan G...I'm a Mopar Addict
Reply #3 on:
December 24, 2013 - 04:56:12 PM »
I don't know about "BUTT" welding....I would used a mig welder....
I wouldn't over lap the seem though, and just like said above, only replace as much as you need AFTER a good cleaning of the fender....just don't assume rust is only in one place...Correctly strip the entire fender and fix all the rust.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
The Body Shop
(Moderator:
Chryco Psycho
