Author Topic: passion 5 speed questions (not out yet!)  (Read 3611 times)
Re: passion 5 speed questions (not out yet!)
« Reply #15 on: January 01, 2014 - 03:41:17 PM »
I have used both the Tilton & McLeod hyd systems , both work well & mount to the front of the trans so there is zero linkage , hyd clutches do work well
Offline halle09
« Reply #16 on: January 03, 2014 - 12:00:20 PM »
how is it to install as far as the mcleod system on the fire wall and clutch pedel? Whats involved in mounting and inatalling?
« Reply #17 on: January 03, 2014 - 06:01:31 PM »
I did it the retard way , custom built the pedal & mount & used a master cyl from a wrecker , i saved a bunch of $$ but ...... Have I mentioned I have been broke virtually all of my life  :banghead:
 It works but I would do it differently .
Offline 73EStroker
« Reply #18 on: January 04, 2014 - 10:30:02 AM »
I hear you Neil about the $$$$. For others, I am looking at a similar conversion but will have to remove my gearbox (5th time now-1st for my Passon) as I will use the Hydramax conversion. Nice feature they have is the master cylinder swivels with the pedal travel. That is a nice design that will take the stress off where the rod enters the MC. Unfortunately the cost is $619 for the kit but I am 100% sick of trying to get the mechanical system right.
Barry (Salmon Arm)
Offline halle09
« Reply #19 on: January 04, 2014 - 03:53:42 PM »
what do you guys think of the mcleod kit for $480 for the a833? HAS ANYONE EVER INSTALLED IT IN AN EBODY WITH EASE? OR GOOD RESULTS?
« Reply #20 on: January 04, 2014 - 10:48:31 PM »
Yes , both the Tilton & Mcleod work great , no problem with the results just a bad pedal design , Using a stock pedal & mount they work great , I have installed a few on customer cars as well as my own
Offline halle09
« Reply #21 on: January 05, 2014 - 03:42:28 PM »
whats the extent of customizing to fit in a ebody? (drilling new holes or welding for example)
« Reply #22 on: January 05, 2014 - 09:48:59 PM »
Nothing if you use the right parts , the master can mount up to the pushrod hole & use the factory pedal , the braided lines run from the master cyl into the belhousing right onto the slave cyl , Just do not use the Keisler Master as it has no bleeder & you leg will fall off trying to bleed it out , there is another master that works far better & has a bleeder that bolts up the same way .
Offline halle09
« Reply #23 on: January 06, 2014 - 09:12:18 AM »
sounds like the mcleod kit is the way to go then for plug and play
