Author Topic: Canadian 73 Cuda Restoration; Project Sassy.  (Read 109711 times)
Offline twalker
« Reply #120 on: October 12, 2014 - 11:38:02 PM »
GYSOT fellas!!!  Time to crack beers open.
« Last Edit: October 13, 2014 - 05:43:27 PM by twalker »
Re: Canadian 73 Cuda Restoration; Project Sassy.
« Reply #121 on: October 12, 2014 - 11:41:09 PM »
Looks Great!!
Nice work done in a Garage.
 :2thumbs:  :cheers: :clapping:
Offline twalker
« Reply #122 on: October 13, 2014 - 12:09:35 AM »
Looks Great!!
Thanks man!
« Reply #123 on: October 13, 2014 - 06:59:04 PM »
 :2thumbs:
NICE!!
 :2thumbs:
Hope I can do as well in my garage :grinyes:
Nice work twalker  :cheers:
Offline Paul97
« Reply #124 on: October 13, 2014 - 10:17:14 PM »
Inspiring Results     :cooldancing:
Offline twalker
« Reply #125 on: October 13, 2014 - 11:46:04 PM »
Thanks guys
Offline daaboots
« Reply #126 on: October 14, 2014 - 01:28:54 PM »
Excellent work! Any tips for a person that has never painted before? I'd like to paint mine myself in my garage but I'm a little bit afraid of making a huge mess. What kind of equipment are you using?
Offline twalker
« Reply #127 on: October 14, 2014 - 10:21:45 PM »
Thanks!  This was my first time too.  Don't be afraid, it's doable. The hard part is actually the lead up to painting, all the body work to make the panels straight.  I spent 6 months just blocking and prepping panels - I usually put a couple hours in each night, more on the weekends.  Not every night but most.  Here are a few tips I can pass on:
Equipment -
Air compressor is critical, min 60 gal tank and 5hp, good CFM rating, 15-18 I would say.  And a good air dryer min 25ft away from the compressor
air tools - 6" DA sander, air file, jitter bug, ...
Paint guns - get the three gun system! Primer gun, top coat gun, detail (small) gun.  I chose devilbliss starting line - very happy, great price and great guns.
Blocking kit - dura block is what used and 'soft sanders' is another branding kit I highly recommend
Rotisserie or hoist if you are doing metal/body work under the car
Strong and stable saw horses for blocking panels off the car
Large orbital polisher, 8-10 inch wheel, for the cut buff and polish
And all the usual tools to pull the car/panels apart.
Materials -
I sorely underestimated the amount of sandpaper and hi build primer I needed.
Part of this I'm sure is my inexperience in blocking panels, likely use less on the next car.
Choose a good quality paint system and use the whole system - epoxy primer, hi build primer, top coat.  I decided to use eurothane because of my research it should be more user friendly - and I have to say it's great paint.  I chose DuPont nason products, see below for pictures.
Get good quality filler, it'll make your life easier, and get a very good quality polyester finishing 2 part filler, key for the final stages of blocking.
General tips -
The Internet is your friend ... I learned from reading and watching videos.  I watched everything from Kevin tetz, YouTube and paintucation - huge help for me.  Like how to block a panel.
Get a test panel and practice!  I did this to start and it built my confidence.
Patience ... Patience ... Patience ... There were times where I lost mine, it's very tedious to get panels just right.  But it's what makes the paint job turn out.
I'm sure I'm missing some stuff but it's a start.  Let me know if I can help more.
Offline daaboots
« Reply #128 on: October 16, 2014 - 09:01:35 AM »
Thanks. Looks like I have a lot of research to do!
What about preparing your garage? Did you put up plastic sheets and use some type of an exhaust fan? I'm just wondering how you controlled the dust.
Offline 74 challenge
« Reply #129 on: October 16, 2014 - 11:40:02 AM »
ohh man if I painted a car drinking labatt's there would be water marks everywhere - the tears of my tastebuds.  :poopoke:
I would also be interested in pictures of the setup in the garage. I don't think he tented if off because there is green dust in all the pictures.
1-8-4-3-6-5-7-2
Offline twalker
« Reply #130 on: October 16, 2014 - 12:45:36 PM »
Hi guys, I only covered the things that matter in the garage with overspray plastic sheeting.  No tenting, etc.  I have a window in my garage which fits a household box fan perfectly.  I run it high speed when painting.  That's it, nothing special.  Of course I make sure the garage is clean.
Offline twalker
« Reply #131 on: October 16, 2014 - 09:28:47 PM »
Next stage complete...
Should have the doors, mirrors, deck lid and rear valence on the car this weekend.  Yeah!
Also spending time this weekend doing the cut, buff and polish.
Cheers guys
Offline anlauto
« Reply #132 on: October 16, 2014 - 09:30:34 PM »
I think you should paint cars for me  :worshippy
The trunk lock rod cover hanging in the last picture should be black :2cents:
« Reply #133 on: October 16, 2014 - 09:34:27 PM »
Do fumes go into your house?
I've heard this is something to prepare for; like taping the door shut.
Offline twalker
« Reply #134 on: October 16, 2014 - 11:21:43 PM »
Hasn't been a problem so far.  It doesn't take long for the overspray and deep fumes to exhaust out.  The garage smells of paint for awhile of course.
« Last Edit: October 16, 2014 - 11:40:49 PM by twalker »
