Author Topic: Canadian 73 Cuda Restoration; Project Sassy.  (Read 109758 times)
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: Canadian 73 Cuda Restoration; Project Sassy.
« Reply #210 on: March 24, 2015 - 10:33:38 AM »
Great progress!   :2thumbs:
Offline roadman5312
« Reply #211 on: March 24, 2015 - 11:05:17 AM »
 :cooldancing:    Awesome.    :clapping:
Offline twalker
« Reply #212 on: April 05, 2015 - 10:07:20 PM »
Finished my stainless trim polishing today.  Wow, that was a big job.  Thanks to Cody for his how-to video, helped me a lot.
Here is the before:
After:
Where there was deep scratches or dents (had two), used file, then 80, 120, 220 grits.  All the rest of the trim got started at 220, 320, 400, wet 600, 800, 1000, 1500, 2000.  Went up to 2000 because I felt it made things easier at the wheel.  Bought this kit from Eastwood, it worked perfectly.
http://www.eastwood.com/eastwood-1-2-hp-buffmotor.html
http://www.eastwood.com/buff-kit-stainless-aluminum-brass-steel-8-inch.html
Offline twalker
« Reply #213 on: April 05, 2015 - 10:13:26 PM »
Getting ready to epoxy my dash and steering column pieces, they are all blasted and ready to roll.  Got the ppg black suede dash paint ready to go.
« Reply #214 on: April 05, 2015 - 10:25:14 PM »
Go light on the primer so as to not create to much texture.
Remove the grab handle and spray separately on your ash tray.
Ground contacts need to be bare metal. Like any dash mounting screw areas.
« Last Edit: April 05, 2015 - 10:27:26 PM by Topcat »
Offline twalker
« Reply #215 on: April 05, 2015 - 10:29:51 PM »
Thanks for the advice, have read about the grounding issues - will be careful to sand those areas.  Still have to prep the parts for paint.
Offline anlauto
« Reply #216 on: April 06, 2015 - 09:00:56 AM »
Not all those parts in that picture are the same shade of black. :2cents:, some are not black at all.
Offline Haddixj
« Reply #217 on: April 06, 2015 - 09:09:42 AM »
oh any chance you can tell which are and are not? On threads like these I save the pics with notes usually for my future resto's.
Thanks
Offline anlauto
« Reply #218 on: April 06, 2015 - 09:14:33 AM »
The three odd shaped brackets for the steering column should be gloss black, the tube for the steering column should be flat black, not textured, steering shaft should be silver, although I've seen some painted black
Offline Haddixj
« Reply #219 on: April 06, 2015 - 09:16:22 AM »
thank you
Offline dfrazz
« Reply #220 on: April 06, 2015 - 09:56:59 AM »
That trim looks beautiful!  :2thumbs:
Offline twalker
« Reply #221 on: April 06, 2015 - 11:51:10 AM »
Thanks Alan!
Offline twalker
« Reply #222 on: April 06, 2015 - 11:52:05 AM »
Thanks!  So many hours...
Offline BFM_Cuda
« Reply #223 on: April 06, 2015 - 12:20:46 PM »
 :iagree:  Trim looks great! Keep up the good work!
Offline blown motor
« Reply #224 on: April 06, 2015 - 12:30:33 PM »
That trim is amazing. Any idea on how many hours that took?
