Author Topic: Canadian 73 Cuda Restoration; Project Sassy.  (Read 109725 times)
Re: Canadian 73 Cuda Restoration; Project Sassy.
« Reply #300 on: August 02, 2016 - 09:14:02 AM »
 :popcorn:
I'll be following your engine build.  I just recently up another 440 block and am going with pretty much the same parts as you. Only major difference will be that i have stealth heads and an 850cfm qf carb with a choke.
 :popcorn:
Offline twalker
« Reply #301 on: August 13, 2016 - 12:27:03 AM »
Back from the machine shop!
Offline twalker
« Reply #302 on: August 13, 2016 - 12:30:11 AM »
Started the initial mockup and checking clearances...
All good so far.  Tomorrow, start mocking up rods and Pistons.
Offline twalker
« Reply #303 on: August 14, 2016 - 04:11:14 PM »
Mockup process continues ... Pistons and rods in and checked for clearance.
Have to shave some material off the oil pickup tube area:
Side to side rod clearance is .020 across all four journals.
Offline twalker
« Reply #304 on: August 14, 2016 - 04:14:23 PM »
Pickup tube mods are done - had to take about 1/2 inch out of the height to fit.  Windage tray fitted and hemi pan, all fits good now.
Offline twalker
« Reply #305 on: August 14, 2016 - 04:17:35 PM »
Just looks mean...
Offline crash340
« Reply #306 on: August 14, 2016 - 04:49:17 PM »
What did you use to measure the pickup clearance? that white sponge looking stuff.
Greg
73 Cuda
Brisbane, Australia
Offline twalker
« Reply #307 on: August 14, 2016 - 04:50:35 PM »
Home made play doh :-). Of all the times for kids to be out of the real stuff....
Sent from my iPad using Tapatalk
Offline daaboots
« Reply #308 on: August 18, 2016 - 08:56:10 AM »
Looking great!
Offline blown motor
« Reply #309 on: August 18, 2016 - 09:23:00 AM »
daaboots! How are you making out with your car?
Offline twalker
« Reply #310 on: August 18, 2016 - 09:25:28 AM »
Echo that!  I've been wondering too.
Offline dave73chally
« Reply #311 on: August 18, 2016 - 04:18:19 PM »
:popcorn:
 :popcorn:
I'm running stealth heads and an 850 holley  :thumbsup: I'll let you know how it works if I ever get it fired up!
73 Challenger
Offline twalker
« Reply #312 on: August 27, 2016 - 10:13:49 PM »
Things are coming along.  Another round of parts ordered - distributor, mopar performance valve covers, prw rocker assembly, a whack of ARP fasteners, timing chain, etc ...
Got the cam in and timing chain.  Degreed the cam and it checks out as it should according to the cam card.  Now waiting for prw assembly to determine push rod length and get them ordered.  Then I'll be able to do the final step in pre-assembly - valve to piston clearance.  Then I can tear this thing down for cleaning, paint and final assembly.
« Reply #313 on: August 28, 2016 - 11:14:01 AM »
Cool  :2thumbs:
Offline twalker
« Reply #314 on: August 28, 2016 - 03:35:43 PM »
Cool  :2thumbs:
Thanks for your help so far!
