Author Topic: Voltage limiter question  (Read 538 times)
Offline Racer57
« on: December 27, 2013 - 04:44:20 PM »
Hooked up dash and the fuel, oil and temp don't work. Used circuit tester on wire leading to limiter and the light comes on but there is no light where gauges hook up. Got frustrated and walked away for now, when I go back I'll hook a ground directly to it and check again.
Question..... while I doubt that I did it, is it possible if the leads are reversed to the limiter that it will blow the limiter ? Its the "new style" with only 2 spade fittings.
Offline HP_Cuda
  • Mopar or No Car!
Re: Voltage limiter question
« Reply #1 on: December 28, 2013 - 02:15:46 AM »
I believe the voltage limiter has a socket which can only be plugged in one way.
Might be a grounding issue...
« Reply #2 on: December 28, 2013 - 09:12:15 PM »
Post a picture of it. Even the solid state regulators should have a ground pin. I think they only go in one way.
Offline Racer57
« Reply #3 on: December 28, 2013 - 09:18:07 PM »
My dash does not have the circuit board.
I found an old one of the type I have and I'm using it, so everything works now.
