Author Topic: Defroster vent  (Read 849 times)
Offline usraptr
Defroster vent
« on: December 27, 2013 - 09:01:43 PM »
So I installed my defroster vent in my '70 'Cuda today and as you can see by the pictures, there is a gap of approx 1/2" between the bottom of the vent and the heat box.  The previous owner had already removed the heater box when I bought the car so again I have nothing to compare it too.  There really isn't any adjustment that can be made in either the mounting of the heater box or the defroster vent so my question is, is it normal to have a gap between them?  Or are you supposed to use duct tape to close the gap or did the factory just consider this good enough? :clueless:
« Last Edit: December 27, 2013 - 09:03:18 PM by usraptr »
(Edited 8-1-17)
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
Re: Defroster vent
« Reply #1 on: December 27, 2013 - 11:12:27 PM »
My understanding (from reading several/various previous posts) is that this is normal.  The design was to draw and mix cabin air when using the defroster.  You're fine the way it is.
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
Re: Defroster vent
« Reply #2 on: December 27, 2013 - 11:27:01 PM »
That's about the way mine is. :2cents:
Offline usraptr
Re: Defroster vent
« Reply #3 on: December 28, 2013 - 12:17:12 AM »
Okay, thanks, just wanted to make sure I wasn't missing a coupling or something else.
(Edited 8-1-17)
Offline HP_Cuda
  • Mopar or No Car!
Re: Defroster vent
« Reply #4 on: December 28, 2013 - 02:03:40 AM »
Yup that's how it left the factory!
 :clapping:
Offline larry4406
Re: Defroster vent
« Reply #5 on: December 29, 2013 - 08:29:06 AM »
The pictures above appear to be non-AC cars.  My 71 AC car has a "gasket" there.
Offline anlauto
Re: Defroster vent
« Reply #6 on: December 29, 2013 - 08:41:46 AM »
That's the way it was from the factory. :2cents:
Offline HP_Cuda
  • Mopar or No Car!
Re: Defroster vent
« Reply #7 on: December 29, 2013 - 03:15:00 PM »
 :wow:
With AC
Offline dutch
Re: Defroster vent
« Reply #8 on: December 29, 2013 - 03:52:08 PM »
my a/c car has the foam.
*** Bart ***
