Author Topic: Torque converter / flywheel question ?  (Read 1259 times)
Offline LukeSkywalker
  • Plymouth
« on: December 29, 2013 - 08:09:57 PM »
I'm currently looking to buy a new flywheel as the one I have got some really bad teeth on it now, and it keeps making the screetching noise...
I replaced the starter with a new one, but still it sometimes won't take, so I guess the flywheel has to go aswell.
I've found several new McLeod flywheels on Ebay that are supposed to fit the 440 engine, but I'm uncertain what to look for.
I have a 1970 440 engine with a 727 trans. I don't know what flywheel I have on now, but I found they come in either 143T or 130T...
What is the difference between 130t and 143t? Is there a diameter difference?
« Last Edit: April 21, 2014 - 05:21:41 AM by LukeSkywalker »
Offline anlauto
Re: Flywheel question
« Reply #1 on: December 29, 2013 - 09:21:57 PM »
Well...Hate to be the barer of bad news, but your 440 / 727 combo doesn't have a flywheel.
Offline anlauto
« Reply #2 on: December 29, 2013 - 09:24:05 PM »
The ring gear that the starter engages is part of the torque convertor and can not be replaced separately as far as I know.
  • Plymouth
« Reply #3 on: January 04, 2014 - 03:51:07 PM »
Ok, thanks. So what you are saying is I need a new torque converter..
That's even worse.. They come in 10" 11" and 12", and alot of rpm numbers or whatever
I haven't got the faintest idea what I need.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #5 on: January 05, 2014 - 09:50:40 PM »
What are the cam specs & what RPM are you turning at highway speed 60/70/75 MPH whatever you usually travel at ?
  • Plymouth
« Reply #6 on: January 19, 2014 - 02:51:56 PM »
Cam and rpm I don't know.. Haven't driven the car much...
According to HP_Cuda's post I found and bought one that I think might be close enough...
Quote
Description:    Mopar 727 Torqueflite 11" Street/Strip High Performance Converter (without balance weight)
2400-2700 rpm stall
10" Bolt Circle
Features:    - Highest quality 11" on the market
- New Torrington bearings between stator and pump
- Rebuilt sprag assembly
- New pump hub
- New turbine hub
- Computer balanced
- All hubs, pads, splines, pilots, and bushings are parallel, perpendicular, and concentric to one another for a perfect fit and alignment, Guaranteed!
- All torque converters are factory pressure tested and checked for balance before shipping.
- Made in the USA
Other:    TECHNICAL NOTES; APPLICATION GUIDE
INSTRUCTION NOTES: APPLICATION CHART
Our 11 inch street converters are designed for the enthusiast with modified engines such as mild cam, dual plane intake, headers, or rear gear modifications. An excellent converter for a mild 440 engine. Rated up to 500 HP.
Characteristics:    Part Type: Torque Converters
Part Number: BEP32008
Advertised Flash Stall Rating (rpm): 2400-2700 rpm
Anti-Ballooning Plate: No
Lockup: No
Diameter (in): 11.000 in.
Furnace Brazed: Yes
Balanced: Yes
Hope that will do the job..
Thanks for your help guys :)
Offline HP_Cuda
  • Mopar or No Car!
« Reply #7 on: January 20, 2014 - 01:16:46 PM »
No problemo, let us know how it goes!!!
 :2thumbs:
