Author Topic: Reinstalling leaf springs  (Read 3761 times)
Offline mrbill426
    • All Around Mopars
« on: December 31, 2013 - 12:28:43 AM »
 :1zhelp:  I am about finished "detailing" my rear axle assembly  and am about ready to reinstall the leaf springs.  Is there a good procedure (pics help) for making sure they are on "straight"?  It looks as though the parts don't go together in an exact fashion, but leave some wiggle room as the U-bolt nuts are tightened up.  The axle is off the car which is still on a rotisserie,  and will be installed later.
Thanks!
 :working:
« Last Edit: December 31, 2013 - 01:01:31 AM by mrbill426 »
MOPAR or NO car!
'72 'Cuda 340, white on white
'72 Sebring; bracket project
'66 Imperial Crown; parts car
Re: Reinstalling leaf springs
« Reply #1 on: December 31, 2013 - 07:29:54 AM »
I'm having a hard time remembering so it must not have been an issue, seems the spring center bolt placed everything.....I do recall having to tighten the U-bolts a little at a time to keep straight.
This article may clear it up for you  http://www.moparmusclemagazine.com/techarticles/suspension/mopp_0303_installing_offset_hangers/photo_19.html
« Last Edit: December 31, 2013 - 08:38:44 AM by Bullitt- »
Offline Katfish
  • 70 Challenger
« Reply #2 on: December 31, 2013 - 08:30:13 AM »
The locating pin on the spring will align everything.  Once it fits in the perch hole, and the U-bolts are tightened, it will all come together.
You might be able to nudge it slightly before you torque it down, but I wouldn't think much.
Offline anlauto
« Reply #3 on: December 31, 2013 - 10:50:19 AM »
Yes, everything will fall into place and self-center itself with no problems. :2thumbs:
If you've had the front hangers apart you shouldn't tighten the large shackle bolt until the car is under normal load. :2cents:
Offline mrbill426
    • All Around Mopars
« Reply #4 on: December 31, 2013 - 12:56:26 PM »
Thanks guys  :)
I just want to be sure the springs are parallel to each other and to the frame when it's all bolted back on the car, so the wheels are pointed straight down the road.  When we pulled the axle assembly out one spring was pivoted and "pointed" off at a slight angle.  My body man said it appeared as though at one time in the past a tow truck driver may have yanked the car out of a ditch using the spring as a tie point :swear:  .  This car has been wrecked at least once.
Anyone know the torque specification for the U-bolt nuts?  And.... how long should the bolts be?  I am using Mopar performance U-bolts that I bought some time ago along with their super stock springs and front hangers  (which I decided not to use on this car) but they are awfully long.
 :working:
« Last Edit: December 31, 2013 - 04:10:50 PM by mrbill426 »
MOPAR or NO car!
« Reply #5 on: December 31, 2013 - 06:19:40 PM »
 service manual (1973) says 45 foot pounds
Offline mrbill426
    • All Around Mopars
« Reply #6 on: December 31, 2013 - 10:52:55 PM »
Thanks Bullitt  :thumbsup:
MOPAR or NO car!
« Reply #7 on: January 01, 2014 - 12:23:17 AM »
I just want to be sure the springs are parallel to each other and to the frame when it's all bolted back on the car, so the wheels are pointed straight down the road.  When we pulled the axle assembly out one spring was pivoted and "pointed" off at a slight angle.  My body man said it appeared as though at one time in the past a tow truck driver may have yanked the car out of a ditch using the spring as a tie point .  This car has been wrecked at least once.
Actually, E body springs are not parallel to each other nor to the frame. They are splayed wider at the shackle than at the front hanger by 1.67 degrees.  If you altered the location of one side, you may find the housing doesn't drop on to the centering pins.
Offline mrbill426
    • All Around Mopars
« Reply #8 on: January 01, 2014 - 12:56:52 AM »
Housing on to the center pins?  :clueless:
I'll snap and post a photo tomorrow of what  have so far.  The inside (side to side) measurement between the front and rear spring eyes varies by about 1/8" right now, with U-bolts just snug.
 :working:
MOPAR or NO car!
Offline Rich G
« Reply #9 on: January 01, 2014 - 12:33:44 PM »
Don't forget there is a left and right spring too. ( at least the with the Mopar Performance springs)
Offline mrbill426
    • All Around Mopars
« Reply #10 on: January 01, 2014 - 10:13:21 PM »
Here are shots of what they look like now.
Rich G, both springs are stamped with the same part number of 3643594 and have the same number of leaves so I am assuming they are the same, left and right.
I understand the splayed concept now... am I going about this in the wrong fashion?  :dunno:  Figured it would be easier to install the springs and axle on the car as a unit; should I be planning on putting the springs on the car first and then lowering the axle down on top of them?  Seems awkward that way.  :eek4:
 :working:
MOPAR or NO car!
« Reply #11 on: January 01, 2014 - 11:05:13 PM »
Wrong? No, not necessarily.  Some guys like to install as a unit, some don't.  I usually will install the springs into the front hanger, then install the housing on the springs, then lift the whole thing up and hook up the shackles.
If you install as an assembly like you have it, you will want to loosen up the u-bolt nuts so you can slightly move the springs side to side. This will be necessary to get them into the splayed mounting position. If you torque everything now as is, you're going to be fighting them to get them into the car.
Offline mrbill426
    • All Around Mopars
« Reply #12 on: January 01, 2014 - 11:15:51 PM »
Ahhh I get it  :thinkerg:, I wasn't thinking outside the box there... makes perfect sense now.  Thanks!  :thumbsup:
MOPAR or NO car!
Offline twalker
« Reply #13 on: January 02, 2014 - 06:08:03 AM »
Just had to say - nice detailing job on the assembly!!!
Sent from my iPad using Tapatalk
« Reply #14 on: January 02, 2014 - 09:33:41 AM »
You need to install the front hangers onto the springs before you bolt them to the car.  There isn't enough room to install the bolt if the hangers are installed first.  Like Allan said, leave the nut/bolt loose until the car is sitting on its suspension.  I'd also leave the shackle nuts loose too.
Are your u-bolts loose or are they tight?  I'd leave them loose until the springs are bolted up...That way there is some movement at the centering pin.
